kurfbird Member
Posted: Sat Jul 18, 2009 5:56 pm Post subject: |
I have mint set of gray front seat belts. Not cracked or broken.
I have door sills cant rember what side is cracked. Will have to take a look.
I ahve a nice dash pad. Croner has a cracked but still complete.
| dlp wrote: | Do you still have the front seat belts and door sills? Decent shape?
Couls alo use a good dash pad. The guy that I bought the convertible from screwed snap buttons into the pad. #$*&, pad is great shape except for the holes. |
_________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
dlp Member
1990 Chevrolet Camaro IROC-Z
Posted: Mon Jul 20, 2009 6:14 pm Post subject: |
| How much for the seat belts and non cracked door sill? |
cameron7710 Member
Posted: Tue Aug 04, 2009 11:21 pm Post subject: |
if u have it how much for the driver side rear lower control arm my buddy need one for his iroc _________________
Posted: Wed Aug 05, 2009 12:30 am Post subject: |
| kurfbird wrote: | | DBL_TKE wrote: | | I'll take the front grill if it's in good condition. T-5 tranny by any chance? If so I'll take everything needed for the swap. |
Grilles Camaro decided to sell it. SO you have first dibs.
cameron7710 hows 20 bucks sound.
I am going to tacoma on saturday. 20.00 would be fine if you meet me on the way. It will be early |
I totally forgot about this post, If you didn't hand them off to somebody else yet then I'll take it, How's $15 sound? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Aug 05, 2009 12:31 am Post subject: |
| 83Z28BlackBetty wrote: | Hey if Derek doesn't want that grill, i may be interested. is it the bowtie one or the camaro one?
~JAKE |
Derek has a Firebird so I don't think he wants the grill.  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Aug 05, 2009 11:05 am Post subject: |
i always get you two confused sorry |
kurfbird Member
Posted: Wed Aug 05, 2009 9:52 pm Post subject: lower control arm |
| cameron7710 wrote: | | if u have it how much for the driver side rear lower control arm my buddy need one for his iroc |
I dont know wha tto ask. Make and offer _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Sat Aug 08, 2009 3:21 am Post subject: |
I am interested in the following parts:
-IROC grill
-Wonderbar
-24mm rear sway bar
-IROC steering box
-IROC tail lights
-Air dam
-Ash tray return spring
-Rear hatch area carpeting
Do the badges say Z28 or IROC? I'm interested in the Z28 ones.
What rear end gears does it have? Open or posi? Disc or drum? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
kurfbird Member
Posted: Sat Aug 08, 2009 8:06 am Post subject: |
| DBL_TKE wrote: | I am interested in the following parts:
-IROC grill
-Wonderbar
-24mm rear sway bar
-IROC steering box
-IROC tail lights
-Air dam
What rear end gears does it have? Open or posi? Disc or drum? |
Grille was panted gold so 15.00 would be fine
Wonder bar 25.00
24 mm rear bar. I will have to check to be sure 20.00
-IROC steering box SOLD
-IROC tail lights SOLD
Air Dam No good Broken
Hatch area carpet 15.00
Badges are SOLD
Rear end is SOLD
Ash tray spring I will have to check have to check if it there. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Aug 10, 2009 4:27 pm Post subject: |
| kurfbird wrote: | | DBL_TKE wrote: | I am interested in the following parts:
-IROC grill
-Wonderbar
-24mm rear sway bar
-IROC steering box
-IROC tail lights
-Air dam
Wonder bar 25.00
Badges are SOLD
Rear end is SOLD
Ash tray spring I will have to check have to check if it there. |
Let me know if the sway bar is 24 mm or not, I'll definitely take to Wonderbar and grille though, I would need to see the carpeting in person or pictures to see if it's in better condition than mine. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
kurfbird Member
Posted: Mon Aug 10, 2009 4:59 pm Post subject: parts |
sway bar is 23 mm
give me your email and I will send you some pics of the carpet _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Aug 10, 2009 5:05 pm Post subject: |
SKYCARD213@gmail.com _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
fulkerl New Member
Posted: Mon Aug 24, 2009 6:50 pm Post subject: |
| looking for a auto radaitor for a v8, do you have and how much.. thanks Larry |
kurfbird Member
Posted: Mon Aug 24, 2009 7:44 pm Post subject: radiator |
| fulkerl wrote: | | looking for a auto radaitor for a v8, do you have and how much.. thanks Larry |
Yes I ahve a auto radiator 25.00 plus shipping
Also ahve not forgot about the carpet. Just been busy _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
fulkerl New Member
Posted: Mon Aug 24, 2009 8:04 pm Post subject: |
| will be in marysvill next couple of weekends, could meet some where. let me know if anythng will work for you. thanks Larry |
Outlaw28 Member
Posted: Fri Aug 28, 2009 8:34 am Post subject: |
| you got anything left...do you have the factory y-pipe mine is in sad condition |
kurfbird Member
Posted: Fri Aug 28, 2009 3:20 pm Post subject: y pipe |
Sorry mine sold with the custom exhaust _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Fri Aug 28, 2009 4:53 pm Post subject: |
| Outlaw28 wrote: | | you got anything left...do you have the factory y-pipe mine is in sad condition |
I've still got the factory Y-pipe from my 89, with the cat still attached. _________________ 92 Camaro
91camaro_rs Member
Posted: Tue Sep 01, 2009 10:03 pm Post subject: |
| do you have all the stuff to convert my manual locks to power locks? |
kurfbird Member
Posted: Tue Sep 01, 2009 11:32 pm Post subject: hardware |
What I have has power door locks and power windows includes motors regulators wiring. Dont have power window switches. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
