My Baby Needs Help
kutison
PostPosted: Thu May 28, 2009 1:22 pm    Post subject: My Baby Needs Help Reply with quote
Alright, where should I go to get my ignition lock replaced and my air/fuel mixture for my TBI adjusted? Unless one of you guys can do it and don't mind helping out a cashed-strapped crewbie Sad I am on the east end of the Metro area.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Thu May 28, 2009 3:11 pm    Post subject: Reply with quote
air fuel isn't really adjustable on TBI, if it is off, there is something else wrong, it may have a sensor that went bad, or just needs a tune up.
PostPosted: Thu May 28, 2009 5:11 pm    Post subject: Reply with quote
Replace the ignition lock yourself. It's cheap and you only need a few tools. Where are you located?
What are the engine symptoms? How do you know if the mixture is off?
PostPosted: Fri May 29, 2009 10:40 am    Post subject: Reply with quote
ignition lock is pretty simple. You can have it done in a half an hour. Smile
kutison
PostPosted: Fri May 29, 2009 1:29 pm    Post subject: Reply with quote
I'm in Troutdale, OR Somebody was telling me that it needed so specialized tools, I probably should have bought and looked at the repair manual before I posted this.
PostPosted: Fri May 29, 2009 1:33 pm    Post subject: Reply with quote
The only real specalized tool I think you might need is a steering wheel puller which can be rented at Shucks or Autozone.
If you have an aftermarket wheel, I have one that I put together to get my Grant wheel off, that you could borrow.
PostPosted: Fri May 29, 2009 5:41 pm    Post subject: Reply with quote
Steering wheel lock tool also.
The only other tool you need to take apart a Saginaw column besides screwdrivers, sockets and torx, is the Pivot Pin Puller. It's cheap too but not needed to get to the lock cylinder.
kutison
PostPosted: Thu Jun 04, 2009 5:02 pm    Post subject: Reply with quote
Alright, so I got the steering wheel of with a puller and the plastic cover that is behind it, but now I am down to a metal wheel that is keeping me from getting to the turn signal and lock cylinder. How should I remove this little metal menace? I've pryed at it with an assortment of tools so I am wondering if there is a special tool for it also.
PostPosted: Thu Jun 04, 2009 6:13 pm    Post subject: Reply with quote
Install tool, to depress the lock plate. Use two picks or small screw drivers to pull the snap ring out of the groove.
kutison
PostPosted: Thu Jun 04, 2009 6:15 pm    Post subject: Reply with quote
ah that's what you ment, thanks
kutison
PostPosted: Thu Jun 04, 2009 6:52 pm    Post subject: Reply with quote
if only Crying or Very sad ive been working on it on and off all day Shocked
PostPosted: Thu Jun 04, 2009 8:17 pm    Post subject: Reply with quote
You can rent the lock plate tool as autozone or schucks. The lock ring it a pain to get off, but that's the only really tough part. A couple of small screwdrivers and you got it.
PostPosted: Fri Jun 05, 2009 6:30 pm    Post subject: Reply with quote
sorry buddy. i've done it so many times now it doesn't take me long at all. But like they said. get that lock plate tool and once that is off, the rest is straight forward. Smile
kutison
PostPosted: Tue Jun 09, 2009 7:10 pm    Post subject: Reply with quote
and here is another question that probably has an obvious answer
I got the lock plate tool and compressed the plate, which exposes the ring that I need to remove, I can rotate it in the grove, but how do I get it to slide up onto the lock plate adapter?
I managed to force a large flathead under my thumbnail trying. Embarassed Crying or Very sad
PostPosted: Tue Jun 09, 2009 7:13 pm    Post subject: Reply with quote
kutison
PostPosted: Tue Jun 09, 2009 7:43 pm    Post subject: Reply with quote
alright, snap ring and the green plate are removed, I am down to the white plate that is manipulated by the turn signal arm, I've taken the springs and screw out of it, but it also wont budge. I need to remove it so I can get to the ignition lock.
PostPosted: Tue Jun 09, 2009 7:56 pm    Post subject: Reply with quote
I think there are 3 screws. 2 of which you get to by turning the signal one way then the other. It also helps to unplug the harness down by the pedals and push the wires up the column. You dont really want to pull them out, just push the switch up enough to get to the screw for the tumbler.
PostPosted: Wed Jun 10, 2009 6:35 am    Post subject: Reply with quote
Don't pull the springs out! Just the 3 screws like Chevymad said. One extra screw for the turn signal actuating cam!
http://www.fiero.nl/forum/Forum2/HTML/088020.html
90droptoproc
PostPosted: Wed Jun 10, 2009 8:01 am    Post subject: Reply with quote
forget when it comes into play, but you need to undo the one screw in the hazard switch also
and if you have tilt, tighten upthe 3 tilt screws while you have it apart
PostPosted: Wed Jun 10, 2009 8:53 am    Post subject: Reply with quote
4
Cool
