88+ V8 T-5 Trans W/ electronic speedo
Goto page Previous  1, 2
PostPosted: Mon Feb 02, 2009 7:20 am    Post subject: Reply with quote
Like Rod said, WC T5's have a SLIGHTLY stronger case. The counter shaft has tappered bearings with a shimmed pre-load while the non world class ones use barrel style bearings. WC T5 has 1st and IIRC2nd gear have 3 piece synchros instead of the single brass.
I'd pick up whatever you can find.
Good luck finding the shifter plate for the bird. They are RARE in good shape. I scored a Camaro one at the JY. First one I'd ever seen that wasn't broken. Now I have two lol
PostPosted: Mon Feb 02, 2009 2:07 pm    Post subject: Reply with quote
Found one on TGO but it is in NY.
http://www.thirdgen.org/techboard/engine-drivetrain-parts-sale/509192-wc-t5-swap-f.html
best of luck!
PostPosted: Mon Feb 02, 2009 5:50 pm    Post subject: Reply with quote
I have a NWC T5 I pulled out of my car when I went with the T56. It's in great shape, comes with a hurst billet plus shifter, flywheel (needs to be surfaced) new in the box stock style clutch, bellhousing, all hydraulics, and a set of third gen pedals. Also new pressure plate bolts, but needs new flyweel bolts. Flywheel bolts been taken off and on too many times and I tossed them. They are about $10 for new ones.
PM me if interested. Want to sell it as a package deal.
PostPosted: Tue Feb 03, 2009 12:40 am    Post subject: Reply with quote
PM sent alloy, Jake thanks for lookin! I wouldn't know the first thing about shipping from NY tho... lol
PostPosted: Wed Feb 04, 2009 10:02 pm    Post subject: Reply with quote
not anymore. stopped doing the hardwood run on I-5 now just local here in spokane.
PostPosted: Thu Feb 12, 2009 3:37 am    Post subject: Reply with quote
rjmcgee wrote:
The speed sensor fits in the older 83 and up trannys the same as the speedo gear, it's a direct swap. Finding the speed sensor is a whole differant story. If I remember right the camaro used a speedo cable after they went to an electric speedo, used some sort of buffer box or something. The Firebird went to an electric speedo in 87 and it was just a plug in on the speed sensor on the transmission.
If you end up needing a bird speed sensor let me know, I junked a firebird this summer that had one in it, so I have a spare.
Can I use the speed sensor thats in the automatic?
If I happen to get an older tranny.
PostPosted: Thu Feb 12, 2009 7:15 am    Post subject: Reply with quote
Nope, their differant. Gotta be a five speed VSS. I'll sell you my extra one since I'm getting rid of Jenn's Firebird
HONDASLAYER
PostPosted: Sun Mar 29, 2009 9:05 am    Post subject: Reply with quote
i just picked up my t5 last sunday from an lkq for 150 bucks with a 30 money back garontee(sorry i don't know how to spell that one). i have an 83z28 and i pulled a t5 w/c from an 88 firebird. try looking around at lkq(you pull it). Rock on!
<div>Quizzes Girls Games</div>
PostPosted: Sun Mar 29, 2009 6:49 pm    Post subject: Reply with quote
Son of a B!
$150? is there something wrong with it?
HONDASLAYER
PostPosted: Sun Mar 29, 2009 7:36 pm    Post subject: Reply with quote
i just put it in today and boy oh boy it's freakin strong 100 times stronger than my 83 t5. it had to have been rebuilt just before it landed at lkq. there's not even any road grime on it. i got really lucky.
PostPosted: Sun Mar 29, 2009 8:00 pm    Post subject: Reply with quote
Which one? do you have there number by chance?
HONDASLAYER
PostPosted: Sun Mar 29, 2009 8:09 pm    Post subject: Reply with quote
I GOT MINE IN TIGARD BUT IT WAS THERE ONLY ONE. YOU'VE JUST GOT TO LOOK AROUND AND CALL THEM ALL. I LIVE IN VANCOUVER WA AND HAD TO DRIVE 40 MIN TO PULL MINE, YOU MIGHT HAVE TO DO THE SAME. IF THE TRANNY IS GOOD BE PREPARED TO DRIVE A LONG WAY TO GET IT. T5'S SEEM TO BE HARD TO FIND.
PostPosted: Sun Mar 29, 2009 8:33 pm    Post subject: Reply with quote
Cool, appriciate it.
I got everything to swap it except the trans right now, I live about 20 minutes from the tigard LKQ If I knew it was there I woulda jumped on it soooooo fast, I know they seem to be pretty hard to find.
HONDASLAYER
PostPosted: Sun Mar 29, 2009 8:45 pm    Post subject: Reply with quote
try checking craigslist in seattle and salem. like i said if it's a good tranny it's really worth the traveling
HONDASLAYER
PostPosted: Sun Mar 29, 2009 9:03 pm    Post subject: Reply with quote
try this guy. http://portland.craigslist.org/clk/pts/1092304399.html .
Page 2 of 2
