88+ V8 T-5 Trans W/ electronic speedo
PostPosted: Sun Feb 01, 2009 9:25 pm    Post subject: 88+ V8 T-5 Trans W/ electronic speedo Reply with quote
700R4 is going south, I scored 5 speed 'pedals' from Chris, (emphasize on the "d") lol
But I need a bell housing, an actual tranny, a shifter plate, and hydaulics.
Keep your eyes pealed for me! Cool
'88 FORMULA
PostPosted: Sun Feb 01, 2009 9:37 pm    Post subject: Reply with quote
check this guy out i was emailing him back and forth as of last week he had it i was thinking bout getting it but then i took my car to the bodyshop and cleaned me out , i know its a wase a way but i think its worth it
http://corvallis.craigslist.org/pts/996668143.html
PostPosted: Sun Feb 01, 2009 9:52 pm    Post subject: Reply with quote
That would be nice, but being an '84 it will have a cable driven speedo, and its a non World-Class.
PostPosted: Sun Feb 01, 2009 9:55 pm    Post subject: Reply with quote
He's right on the Non-WC, but the speedo part is easy to convert.
PostPosted: Sun Feb 01, 2009 9:57 pm    Post subject: Reply with quote
ok whats the WC part cause what he needs is what i need to be looking for to and im always on the lookout down this way
PostPosted: Sun Feb 01, 2009 10:01 pm    Post subject: Reply with quote
1988 and up the T-5's were upgraded with some better internals... Exactly what that means I don't know....
But im sure somebody could be nice enough to tell us!
PostPosted: Sun Feb 01, 2009 10:05 pm    Post subject: Reply with quote
What do you think this is, some sort of wealth of knowledge or something?! Very Happy
PostPosted: Sun Feb 01, 2009 10:06 pm    Post subject: Reply with quote
WC = World Class, as I understand it was a buzz-word at the time for a way of doing business, but that's when the tranny was upgraded with some better internals.
Laughing so hard it hurts
PostPosted: Sun Feb 01, 2009 10:10 pm    Post subject: Reply with quote
alrighty then i'll be keeping an eye out for an 88 an up thanks for the info guys
PostPosted: Sun Feb 01, 2009 10:19 pm    Post subject: Reply with quote
There ya go, thanks for looking Greg.
Any of you guys know the going rate at the JY for one of these bad boys?
PostPosted: Sun Feb 01, 2009 10:20 pm    Post subject: Reply with quote
i found one in a yard down here they quoted me well over $300 just for the trans alone so i told em to keep it lol
PostPosted: Sun Feb 01, 2009 10:27 pm    Post subject: Reply with quote
http://seattle.craigslist.org/skc/pts/1010786402.html
Worth a call based on that price alone.
I would jump on that if they give me a warranty wth it. I don't wanna pay $500 plus for another automatic, Id rather replace clutches. lol
PostPosted: Sun Feb 01, 2009 10:29 pm    Post subject: Reply with quote
Is that out of a 4 wheel drive or something? I haven't seen one with the shifter in the middle before.
PostPosted: Sun Feb 01, 2009 10:35 pm    Post subject: Reply with quote
Whoop, it is. I actually bothered to load the images this time. Laughing Never mind then, no wonder he's unloading it so cheap.
PostPosted: Sun Feb 01, 2009 10:36 pm    Post subject: Reply with quote
That explains it because I had looked at that add before. lol
PostPosted: Sun Feb 01, 2009 10:37 pm    Post subject: Reply with quote
The speed sensor fits in the older 83 and up trannys the same as the speedo gear, it's a direct swap. Finding the speed sensor is a whole differant story. If I remember right the camaro used a speedo cable after they went to an electric speedo, used some sort of buffer box or something. The Firebird went to an electric speedo in 87 and it was just a plug in on the speed sensor on the transmission. I finally bought a whole transmission from the junk yard just to to get that speed sensor for Jenn's bird. At least a couple years ago nobody was making one that you could buy, some parts stores could produce part numbers but couldn't order one. Maybe Ian could check to see if it can be had from GM.
If you end up needing a bird speed sensor let me know, I junked a firebird this summer that had one in it, so I have a spare.
As for the world class thing, they are stronger. The one I bought from the junkyard is a WC out of a V6 and there is quite a bit more reinforcment in the case. Plus there were a couple differances in bearings. Not going to be a big differance, but would be the prefered way to go. I wouldn't pass up a good deal on an older non-WC though, I have been running one for the last five years with great luck, and that's with 300 rwhp. Run a 13.0 on slicks with it. Only time it broke was at Cows a couple years ago with a busted shift fork. Nothing says fun like a 350 mile drive home with 4.10 gears and no overdrive. The T5 isn't as pathetic as people make them out to be, plus there are about 30 - 40 lbs lighter and $800 cheaper than a T56.
PostPosted: Sun Feb 01, 2009 11:04 pm    Post subject: Reply with quote
I have everything but the actual t-5. 2 bell housings, 1 set of pedels ( clutch/brake pedal) complete hydaulic setup( resevoir hard lines master and slave cylenders with mounting bracket) and 2 electric speedo sensors. left over from installing a w/c t-5 in my t/a.
PostPosted: Mon Feb 02, 2009 12:56 am    Post subject: Reply with quote
It seems the T5's can definetly take more abuse than 700R4's (in stock form at least).
Big D- You ever in the Portland area for any reason?
PostPosted: Mon Feb 02, 2009 7:03 am    Post subject: Reply with quote
That might work for the blazer though, no?
