Cascade Crew Message Forums
JohnnyIROC-Z Member
Joined: 14 Jan 2004 Posts: 204 Location: Washougal, WA
1995 Pontiac Formula
Posted: Tue Jan 06, 2009 8:20 am Post subject: |
Just for fun...
Y86: MERCHANDISED PKG, CAMARO RS
VK3: LICENSE PLATE, FRT MOUNTING PKG
VAN: ASSEMBLY PLANT, VAN NUYS, CA
V73: ANTENNA, FIXED
UQ9: SPEAKER SYSTEM, DELETE
UL5: RADIO, DELETE
UB3: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
QPH: TIRE ALL, P215/65R15/N BL R/PE ST TL AL2
NK3: STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
NA5: EMISSION SYSTEM, FEDERAL, TIER O
N90: WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
LH0: ENGINE, GAS, 6 CYL, 3.1L, MFI, V6
K60: GENERATOR, 100 AMP
J41: BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
IPB: ???
GU5: AXLE REAR, 3.23 RATIO
FE1: SUSPENSION SYSTEM, S0FT RIDE
E9Z: SPEEDOMETER KEY (DELETE)
E5Z: SPEEDOMETER ADAPTER (DELETE)
D8E: SENSOR, VEH SPD
D80: SPOILER, RR END PNL
D3V: GEAR, SPEEDO DRIVEN
D35: MIRROR, OUTSIDE REAR VIEW
CC1: ROOF HATCH, REMOVABLE PANELS, GLASS
C41: HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AJ3: RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
9UX: COMPUTER SELECTED REAR RIGHTHAND SPRING
8UX: COMPUTER SELECTED FRONT LEFTHAND SPRING----(ALONG WITH 6XW/6ZX)
7XS: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
75U: PRIMARY COLOR, EXTERIOR BRILLIANT RED MET (91)
73I: INTERIOR TRIM, FLAME RED (I) (91)
73B: TRIM COMBINATION, CLOTH, FLAME RED (B) (91)
739: SEAT BELT COLOR, FLAME RED (91)
6XS: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
1SA: Option Package 01
1AY: ???
17P: WHEEL COLOR, SILVER (91)
Only 2 I couldn't find on the thirdgen RPO decoder, I'll look for them later. _________________ 1995 Firebird Formula Onyx Black
91camaro_rs Member
Posted: Tue Jan 06, 2009 2:52 pm Post subject: |
"75U: PRIMARY COLOR, EXTERIOR BRILLIANT RED MET (91) "
thats is what i needed
dang i just learned a whole ton about my car haha |
cameron7710 Member
Posted: Tue Jan 06, 2009 3:01 pm Post subject: |
ya i have the same 2 codes i couldn't find with the decoder but i found
IPB - TRIM, INTERIOR DESIGN _________________
Posted: Tue Jan 06, 2009 3:04 pm Post subject: |
| 1AY = dealer ordered according to Google. |
