Posted: Mon Nov 03, 2008 7:30 pm Post subject: Fog Lights? Baleted. |
Don't mind the rain and chipped paint.
I removed the entire plastic piece, and the foglights, then pulled out the air-funneling plastic pieces, the plastic around the radiator where the AC used to be,, and the metal braces behind the lights that really seem to serve no purpose at all. I then bolted the front half of the air dam back up (sans useless metal braces), and used tin snips to cut out what remained of the plastic in the holes.
A quick trip to Lowes netted me some metal screen that you're supposed to use to cover your chimney or something, but it didn't look cheesy like chicken wire. I shot it with primer, and with a little cutting and bending, and a few well-hidden zipties it was done. I filled the holes from the license plate bracket (which didn't come out very well) and then shot the entire piece flat black, except for the 'Camaro' part. Not bad for a couple bucks and an hours work.
If anyone wants the metal brace things, or the foglights (one has a chipped lens), they're yours for a beer:
GREG DAVIDSON Member
Posted: Mon Nov 03, 2008 7:49 pm Post subject: |
it does look alot better without the fog lights good job  _________________
dlp Member
1990 Chevrolet Camaro IROC-Z
Posted: Fri Nov 07, 2008 10:49 pm Post subject: |
| Maybe it's just me, but IROC's need the driving lights. Deleting them makes them look like an RS. |
Posted: Fri Nov 07, 2008 11:14 pm Post subject: |
| Looks good. Since nobody spoke up, I'll take the lights off of your hands. I have on broken on my Red car, just not sure which one. |
Richster Magic Fingers
Posted: Sat Nov 08, 2008 8:56 am Post subject: Nice Job |
I'm a TA guy, so the open grill reminds me of early year trans Am, it looks clean! and for the price..WOW _________________
Posted: Sat Nov 08, 2008 6:37 pm Post subject: |
| rjmcgee wrote: | | Looks good. Since nobody spoke up, I'll take the lights off of your hands. I have on broken on my Red car, just not sure which one. |
Not sure which one?? Are you saying you don't know your left from your right?  _________________ 92 Camaro
Posted: Sat Nov 08, 2008 7:44 pm Post subject: |
Looks cool Aaron. Did you see that thread on TGO from BluZee? _________________
Posted: Sun Nov 09, 2008 4:09 am Post subject: |
Not until you mentioned it just now. I had thought about doing a full grill like that on it, but it's kinda ricer, kinda expensive, and kinda more work than I wanted to put into it for scant performance gain.
He did a good job on it though, and his emblem idea is interesting, but it ruins the entire point of deleting the foglights, since airflow is still restricted. |
Posted: Sun Nov 09, 2008 11:00 am Post subject: |
| Sorry to say, but you're not going to gain any performance by deleting the fog lights. |
Posted: Sun Nov 09, 2008 5:12 pm Post subject: |
| I figured anything I gained would have been from pulling all the air box junk out, not the lights themselves. It does run about 10* cooler at high speed though. |
Posted: Mon Nov 10, 2008 7:34 am Post subject: |
Do you not have an air dam?
And if you think about it.... Firebirds have no airflow or performance then  |
Posted: Mon Nov 10, 2008 8:04 am Post subject: |
| Twilightoptics wrote: | And if you think about it.... Firebirds have no airflow or performance then  |
We all knew that was the case! :p |
Posted: Mon Nov 10, 2008 8:09 am Post subject: |
I have the same wire mesh in my grill.
I would have kept the plastic in around the radiator. Helps keep cold air out front, and hot air in the bay rather then up into the snorkle. |
Posted: Mon Nov 10, 2008 12:08 pm Post subject: |
| Twilightoptics wrote: | Do you not have an air dam?
No, the air dam is still all there. However without the foglights and the air funnel things in there I noticed two things:
1) The air coming through the foglights holes has a straight shot through the lower half of the rad, and is no longer blocked by the lights or the braces.
2) Air pushed up by the air dam now has a straight shot upwards towards the dual filters and upper hafl of the radiator, instead of being blocked by the funnels and air box silencer.
Like you said, I doubt there's a real performance gain to be had, but it didn't hurt my cooling any. |
Posted: Tue Nov 11, 2008 9:21 am Post subject: |
Sho ya right!
