12's still aren't free.... Got Power?
PostPosted: Thu Nov 06, 2008 7:00 pm    Post subject: 12's still aren't free.... Got Power? Reply with quote
Got my parts together for the Torque arm so I figured it's time to build it.
Got under and started dissassembly.
Well... Found some more bent parts.
Lots of work to do. Going to redesign the crossmember for the Torque Arm Mount. Then fit in the panhard. Then get the driveline. Then make the torque arm. Driveline might have a large shaft so I don't want to make the T/A and discover the DL doesn't fit.
Looks like I might be dynoing the wankel.
Rock on!
PostPosted: Thu Nov 06, 2008 7:32 pm    Post subject: Reply with quote
Holy crud bubba! I feel your pain. "Speed costs money, how fast do you want to go".... I hate that saying. Has proved to be very true.
Sorry about the carnage.
So what is this wankel that you tease about?
PostPosted: Thu Nov 06, 2008 7:37 pm    Post subject: Reply with quote
Just a little commuter car.
PostPosted: Thu Nov 06, 2008 7:44 pm    Post subject: Reply with quote
Shocked
Wow.
Is that the one I traded you?
PostPosted: Thu Nov 06, 2008 8:03 pm    Post subject: Reply with quote
Shocked
Wow.
Yup. Made ground beef out of it. Even bent the splines on the yoke.
PostPosted: Thu Nov 06, 2008 8:33 pm    Post subject: Reply with quote
Nice. Should call Northwest driveline and tell them their shaft failed again. Laughing
PostPosted: Thu Nov 06, 2008 8:41 pm    Post subject: Reply with quote
DOOOO IT!!!!!
PostPosted: Thu Nov 06, 2008 8:52 pm    Post subject: Reply with quote
I know for a fact that I couldn't just throw a stickfit to get that one fixed like I did last time. Sorry man. Laughing
PostPosted: Fri Nov 07, 2008 7:25 am    Post subject: Reply with quote
LOL
Need to upgrade now obviously anyway!
PostPosted: Fri Nov 07, 2008 9:15 am    Post subject: Reply with quote
I wonder if the driveline damage didn't happen from having some very big mis-alignment in there when the torque arm bent.
Sorry to see that much damage...bigger, faster, stronger.
--John
PostPosted: Fri Nov 07, 2008 9:32 am    Post subject: Reply with quote
Driveline happened from racing dude.
Bad angles shouldn't do that.
Plus, when I built the torque arm mount before racing, the driveline had to come out, and it was straight.
PostPosted: Fri Nov 07, 2008 9:38 am    Post subject: Reply with quote
I'd fire the engineer and the fabricator. Laughing
PostPosted: Fri Nov 07, 2008 12:31 pm    Post subject: Reply with quote
That sucks dude.
But the carnage is pretty impressive.
did you ever sell the C-vette?
PostPosted: Fri Nov 07, 2008 1:21 pm    Post subject: Reply with quote
well if your breaking stuff like that that either means your doing somthing right or horrably wrong !!! and from what i've seen of your car it has to be right i agree with dewey bigger faster stronger !
PostPosted: Fri Nov 07, 2008 1:25 pm    Post subject: Reply with quote
Laughing
Looks like you rifled your slip yoke? Hehe.
PostPosted: Sat Nov 08, 2008 5:27 pm    Post subject: Reply with quote
The Wankel is the name of the rotary engine in the RX-7s, right?
PostPosted: Sat Nov 08, 2008 6:16 pm    Post subject: Reply with quote
Correct. Tis the name of the designer.
