A little work on old wheels
Goto page 1, 2, 3  Next
PostPosted: Sat Nov 01, 2008 3:56 pm    Post subject: A little work on old wheels Reply with quote
It's kind of a late start, but since I still have the stock wheels for my 89 and they won't fit over its brakes anymore, I decided to use them for winter wheels on my 92.
Probably won't happen this winter, but I took the finish off one of them with generous amounts of aircraft stripper, a wire wheel, and 100 grit sandpaper. Aircraft stripper does wonders on the clear coat that was on the wheel I did, but took a little more work to get the red color almost all the way off. Then 100 grit sandpaper took the color almost 100% off. I used a small 80 grit paddle wheel to finish up the back side of the wheel as much as possible.
Now I have 3 more to do before I put a different color paint (black??) on them. Maybe three more weekends
Here is the result of about 5-6 hours of work (mostly waiting for the stripper to work) with an untouched wheel on the left.
PostPosted: Sat Nov 01, 2008 8:03 pm    Post subject: Reply with quote
looks good Al!
I always thought those wheels only looked good in the Aluminum color.
PostPosted: Sat Nov 01, 2008 8:29 pm    Post subject: Clean! Reply with quote
Hey Al, the wheel looks clean! the paint is nice, but that strip down look is..clean!
Yea i think the black is the way to go, but that basic aluminum look is crisp...that was some time on the clear coat, what a pain..but nice results for sure!
PostPosted: Sat Nov 01, 2008 9:32 pm    Post subject: Reply with quote
I thought about polishing them. Just too much work for something I'll use only in the winter. There's also a few blemishes that will take lots of work polishing to cover where painting them will take little effort. The red has got to go in any case because these are going on the purple car as winter wheels and I think black would look best Cool
'92 camaro boss
PostPosted: Sun Nov 02, 2008 12:12 am    Post subject: Reply with quote
what happened to the ZO6's?
PostPosted: Sun Nov 02, 2008 8:03 am    Post subject: Re: A little work on old wheels Reply with quote
Al Hasse wrote:
Since I still have the stock wheels for my 89 and they won't fit over its brakes anymore, I decided to use them for winter wheels on my 92.
Z06 wheels are still on the red 89.
The red paint won't go with the purple 92, so these get black paint and become its winter wheels. Cool
'92 camaro boss
PostPosted: Sun Nov 02, 2008 10:05 am    Post subject: Reply with quote
ha, i think i'm done posting after 10.. groggy thoughts make you not able to comprehend things as well
PostPosted: Sun Nov 02, 2008 10:11 am    Post subject: Reply with quote
Where did you buy the aircraft stripper? I have clear coat peeling on my Ford truck. Would look better if it was gone altogether. I'm ready to buy new tires and that would be a perfect moment to do the job.
Magman
1990 Chevrolet Camaro IROC-Z
PostPosted: Sun Nov 02, 2008 10:31 am    Post subject: Reply with quote
Nice job Al! Looks sooo much better! You going to clear coat when done?
1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012)
PostPosted: Sun Nov 02, 2008 10:57 am    Post subject: Reply with quote
Aircraft stripper is available at my local NAPA. It also does a fair job of removing the paint underneath. Cool Costs about $35 gallon which was the only size available at my store and I'll probably need another.
Not sure yet, but probably. I want these a low maintenance as possible since they will be primarily winter wheels.
PostPosted: Sun Nov 02, 2008 6:46 pm    Post subject: Reply with quote
One down, three to go...
It's not perfect, but it'll suit my needs just fine. I still need to clean up the back side some more and maybe put some paint in there, then I'll see about a clear coat.
PostPosted: Sun Nov 02, 2008 8:05 pm    Post subject: Reply with quote
wow that looks awsome alot nice than i was expecting
PostPosted: Sun Nov 02, 2008 8:37 pm    Post subject: Reply with quote
looks good !
PostPosted: Sun Nov 02, 2008 10:15 pm    Post subject: Reply with quote
Al, you rock brother. I would have just rattle-canned them and drunk a beer. But you put some serious work into it, and it looks great. Thumbs up
PostPosted: Sun Nov 02, 2008 11:38 pm    Post subject: Reply with quote
Nice work AL! Those will be the best looking stock wheels i've seen!
PostPosted: Mon Nov 03, 2008 8:18 am    Post subject: Reply with quote
Nice! Looks exactly like what I did to my S10 wheels! I have a picture around here somewhere. Can't wait to see them on!
PostPosted: Mon Nov 03, 2008 8:50 am    Post subject: Reply with quote
Thanks, I can't wait to get them finished up. Two more to strip and three to paint.
Does anyone know where I can get a set of the rings that go around the center caps?? The car didn't have them when I bought it and the wheels don't look finished without them.
PostPosted: Mon Nov 03, 2008 8:51 am    Post subject: Reply with quote
Which rings are you talking about?
PostPosted: Mon Nov 03, 2008 9:38 am    Post subject: Reply with quote
The ones that fit in the recessed area of the lug nuts and surround the center cap. It's been years since I've seen them, IIRC they're secured by the plastic screw on cap for each lug nut. I have all but four of those lug nuts, but no caps which I also need to find....
PostPosted: Mon Nov 03, 2008 11:41 am    Post subject: Reply with quote
Never heard/seen such a ring either.
Page 1 of 3
