2.8 VS 3.1 Injectors
PostPosted: Sun Oct 12, 2008 4:34 pm    Post subject: 2.8 VS 3.1 Injectors Reply with quote
Does anyone know the #/hr rating of both?
PostPosted: Sun Oct 12, 2008 4:48 pm    Post subject: Reply with quote
Don't know about the 2.8, but the set I acquired and had serviced for my 3.1 were tested at 40 lbs. They were all final adjusted to 42. Not sure if that was a per hour pressure or just their tested pressure.
PostPosted: Sun Oct 12, 2008 4:51 pm    Post subject: Reply with quote
40 would be the pressure, not the lb rating.
They are both in the range of 15lbs. You can put 3.1's in a 2.8 and not have any problems at all. 2.8's into a 3.1 you MIGHT run a bit lean.
PostPosted: Sun Oct 12, 2008 4:53 pm    Post subject: Reply with quote
I thought 40 sounded a bit high.
PostPosted: Sun Oct 12, 2008 5:37 pm    Post subject: Reply with quote
I've got a set of six brand new 3.8 injectors if you want them for cheap... Very Happy
PostPosted: Sun Oct 12, 2008 6:14 pm    Post subject: Reply with quote
TGO FWIW says 15lb for the 2.8 and 17lb for the 3.1.
PostPosted: Mon Oct 13, 2008 3:56 am    Post subject: Reply with quote
17lb is 3.4l motor.
PostPosted: Mon Oct 13, 2008 8:03 am    Post subject: Reply with quote
If you get the injectors from a FWD 3.1 then they are definetly 17lb hr.
