		GREG DAVIDSON Member
   1989  Pontiac  Formula
				 Posted: Wed Oct 01, 2008 6:32 pm    Post subject: CHEAP exhaust manifold or headers |
				| trying to get things strait for my swap im wanting to ax the smog control and clean up the engine bay so if anyone has an extra set hit me up must be cheap but work thanks |
   1992  Chevrolet  Camaro RS
				 Posted: Wed Oct 01, 2008 6:59 pm    Post subject:  |
				I still have the manifolds that came off my 305.  The heat shields may not be in the greatest shape, but the manifolds are good. _________________ 92 Camaro
				 Posted: Wed Oct 01, 2008 7:03 pm    Post subject:  |
				| that without the smog tubes on it i dont want those on there or welded shut good enough not to leak |
				 Posted: Wed Oct 01, 2008 7:13 pm    Post subject:  |
				| They have the tubes, I'd leave it up to you to remove and/or seal them up.  If still interested, I'll figure shipping and they're yours. |
				 Posted: Wed Oct 01, 2008 7:16 pm    Post subject:  |
				| nah the ones i have , have the tubes and are fine im just looking for manifolds without the tubes i dont have access to a welder if i cant find somthing i'll just have to pay to have em welded |
				 Posted: Wed Oct 01, 2008 8:13 pm    Post subject:  |
				| Don't bother man. If you aren't putting headers on just block the tubes off for now. You'll put header son eventually. |
		corey davidson Member
   1986  Chevrolet  Camaro
				 Posted: Thu Oct 02, 2008 12:33 am    Post subject:  |
				| i no i will |
   1984  Chevrolet  Camaro Z/28
				 Posted: Fri Oct 03, 2008 12:05 pm    Post subject:  |
				Can't you just get pipe plugs that thread into the AIR spots?
I've never had a thirdgen with the tubes, I bought a brand new set of shorty headers from Summit for around $80 when I built my engine. They were a good buy, but needed some mods to fit right, as well as fabbing a y-pipe. _________________ 84 Camaro Z28 - LS1/T56
   1991  Pontiac  Trans Am
				 Posted: Fri Oct 03, 2008 2:12 pm    Post subject:  |
				 	  | Alphius wrote: | 	 		  | Can't you just get pipe plugs that thread into the AIR spots? |
That's what I did with mine. Manifolds with 1/4" plugs fit perfectly, and I dyno'd ~225hp through 'em with the 305. Only gained ~10hp after I switched to long tubes and 3" Ypipe. _________________
 	  | Quote: | 	 		  | Sometimes I actually think I'm slightly retarded in the mouth. |
				 Posted: Fri Oct 03, 2008 10:43 pm    Post subject:  |
				| thanks guy i think i'm going to take the advise of just plugging them, |
