Posted: Fri Sep 19, 2008 10:51 am Post subject: anyone have a haynes/chiltons manual handy? |
both of mine are in oregon... smart huh.
i am pulling my leaking busted fuel tank out of my 86 this weekend and replacing it with a 91 baffled fuel tank with extra solder around the neck joint. i need the torque specs for the rear end stuff.
Control Arms to Body:
Control Arms to Axle Housing:
Shock Absorbers to Axle Housing:
Sway Bar to Body mount: 14lb/ft right?
Driveline to Yolk: 10Lb/ft right?
Trackbar to Axle Housing:
Trackbar to Body:
Trackbar Brace to Body:
Torque Arm to Rear Axle Housing:
i wrote them all down so you could just copy/paste. thanks in advance. _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
Posted: Fri Sep 19, 2008 11:02 am Post subject: |
I'll do ya one better and break out the '87 service manual:
Control Arms to Body: 68
Control Arms to Axle Housing: 68
Shock Absorbers to Axle Housing: 70
Sway Bar to Body mount: 14lb/ft right? 12
Trackbar to Axle Housing: 93
Trackbar to Body: 58
Trackbar Brace to Body: 58
Torque Arm to Rear Axle Housing: 100 |
Posted: Fri Sep 19, 2008 12:18 pm Post subject: |
wait, they are in the service manual? i have that. i have never found torque specs in it though.
i also finaly found a book today. went to a few more parts stores
EDIT* where are my manners... THANK YOU for looking those up for me |
Posted: Fri Sep 19, 2008 12:32 pm Post subject: |
| Service manuals usually have the torque specs at the end of every chapter. Try the very last page of section 4B. |
Posted: Fri Sep 19, 2008 9:46 pm Post subject: |
Blue Point 3/8 impact wrench, all of them.  |
Posted: Fri Sep 19, 2008 10:03 pm Post subject: |
What I want to know, is why in the world do you un-do that many bolts, to do the gas tank.
Shock bolts, axle LCA bolts, panhard, call it day. |
Posted: Sat Sep 20, 2008 1:33 am Post subject: |
| i wanted all as a "just in case" kind of deal. |
Posted: Sat Sep 20, 2008 3:08 pm Post subject: |
all done. started at 10:30, finished at 3:30. 5 hours. the last time it took me almost 10, time before that around 12.
i did not have to bleed the brakes, i dod not have to remove the control arms, i did not ahve to remove the torque arm. i also choose not to reinstall the heat shielding this time. if the GTA does nt need it the v6 does not either.
found out my rear trac bar is bent.. don't know how that happened. and my sway bar bolts were left off due to thread issues. i'll get some and reinstall tomorow. |
Posted: Sat Sep 20, 2008 5:00 pm Post subject: |
well, my fuel guage does not work anymore. and the tank is still leaking, this time from the filler cap.
this means the tank has to come BACK out. i hate life right now. if i were home i would be in my trans am right now leaving a cloud of smake at a green light to remind myself why i do this, but i'm away from my T/A.. |
Posted: Sat Sep 20, 2008 6:02 pm Post subject: Re: anyone have a haynes/chiltons manual handy? |
| Xophertony wrote: |
Trackbar to Body:
You don't need torque specs on anything in our cars exept for main journals and rod journals. |
Posted: Sun Sep 21, 2008 6:41 pm Post subject: Re: anyone have a haynes/chiltons manual handy? |
| Twilightoptics wrote: | | Xophertony wrote: |
Trackbar to Body:
What about cylinder heads  _________________
Posted: Sun Sep 21, 2008 8:26 pm Post subject: Re: anyone have a haynes/chiltons manual handy? |
| Quasi-Traction wrote: | | Twilightoptics wrote: | | Xophertony wrote: |
Trackbar to Body:
What about cylinder heads  |
Okay and those. |
Posted: Sun Sep 21, 2008 8:35 pm Post subject: |
| And the torx screws on the dash. Over torque those, and you are in for a bad day. |
