Possible fuel pump problem?
PostPosted: Sat Jun 21, 2008 2:11 pm    Post subject: Possible fuel pump problem? Reply with quote
Well right after I finished installing my ball joints I took my car for a little test drive. I tried running through the gears but at the top end of first it just hit a wall. And no, not the "TPI wall" it was much worse than that. It almost wouldn't accelerate anymore. The engine sounded kind of funny too when that happened. Then yesterday I was driving my car and the whole time it was stuttering. Almost as if it wasn't getting fuel. About every couple of seconds or so it would stop momentarily and I could feel the car have full power. Now it happens all throughout the RPM range. I think it could possibly be either be a clogged fuel filter or my fuel pump is going out again. I did however just change the pump a year and a half ago and I did the filter at the same time. Unfortunately I don't have a fuel pressure tester at my disposal, so I can't do any real testing. Do you think I'm right or do you have another idea to what it wrong?
PostPosted: Sat Jun 21, 2008 3:30 pm    Post subject: Reply with quote
Fuel filter is 12 bucks and ten minutes. Change it just to eliminate it. Mine went out after I let the car sit too, and it had less than 5K on it.
PostPosted: Sat Jun 21, 2008 10:36 pm    Post subject: Reply with quote
after you change the fuel filter hook up a fuel pressure tester. if that looks fine pull your dizzy cap. this sounds EXACTLY like what happened to me at cows. my pickup coil had rusted itself to pieces.
PostPosted: Sat Jun 21, 2008 11:27 pm    Post subject: Reply with quote
my car was doing some funny things yesterday to... it might be the heat... cars never like drastic changes in weather.
and we have the filter at knechts for $4.99
'88 FORMULA
PostPosted: Sun Jun 22, 2008 4:10 am    Post subject: Reply with quote
But is it Wix, or is it just Fram? Very Happy
PostPosted: Sun Jun 22, 2008 7:57 pm    Post subject: Reply with quote
umm... its a PTC. but thats ok because skyler is really cheap Laughing
'88 FORMULA
PostPosted: Wed Jun 25, 2008 11:44 pm    Post subject: Reply with quote
Well I picked up the filter yesterday, installed it today and to my disappointment, that wasn't the problem. So I just started messing around in the engine bay and I hate to say it but I think Red was right, it's the heat. Heat soak that is. I moved all the spark plug wires away from the block and manifolds and presto, Smooth running American V8 again. That's the only thing I can think of unless I have a broken wire and I just moved it back into place, but I don't think so.
