charlie6178 Member
Posted: Thu Jun 19, 2008 2:55 pm Post subject: rear disc setup |
| does anybody have a disc brake rear end for sale? i dont' car if it's a posi or not, it could even be broken. i just want a rear end that has the brakes on it. i have a 71 nova SS with a 8.5" 10 bolt and i have currie discs on the front and stock drums in the rear. i just want stock F-body rear brake setup to put on the rear of the car. i'm putting a line lock in it, and all new lines, new ssbc master cylinder, booster, and prop valve so i just want a rear disc setup. if anybody has a spare one layin around i'd greatly appreciate it. |
Posted: Thu Jun 19, 2008 3:19 pm Post subject: |
| Why do you want to put F-body brakes on a Nova? I'm about 80% sure the backing plates from a 7.5" 10bolt wont fit. Usually drums have a different style bolt pattern all together. |
charlie6178 Member
Posted: Thu Jun 19, 2008 6:16 pm Post subject: |
| they are different, but i have a machine shop and i can make brackets to make it work. and i want a third gen F-body rear setup because it'll match the front brakes pretty well, and it will be alot cheaper than aftermarket brakes. it's a drag car anyways so the car stops fine the way it is, i just put some greag weld motorsport wheels on it and i'm not feelin how the drums look. |
Posted: Thu Jun 19, 2008 6:49 pm Post subject: |
| What might you be looking to spend? |
charlie6178 Member
Posted: Thu Jun 19, 2008 8:21 pm Post subject: |
| idk, do you have something? what would you want for it? |
