'92 camaro boss Member
Posted: Sun Feb 17, 2008 6:57 pm Post subject: Power seats |
| I read a long time ago that all camaro had the wires for power seats under the carpet.. is that true?.. |
Posted: Mon Feb 18, 2008 6:50 am Post subject: |
| I had a v6 camaro once that did NOT have the wires. |
Posted: Mon Feb 18, 2008 7:58 am Post subject: |
| my v6 firebird has no such wires. my GTA that came original with power seats DOES have wires. it's just (+) and (-). you can run them yourself with ease if you install power seats. |
Posted: Mon Feb 18, 2008 8:10 am Post subject: |
| alright, idk if the guy who wrote it knew what he was talking about or not.. so about how long would it take to install the new seats then? |
Posted: Mon Feb 18, 2008 9:34 am Post subject: |
| If they're F-body seats, they should bolt right in. Don't forget an in-line fuse on the power wire. Since I've never put any in, I couldn't tell what size to use. |
kurfbird Member
Posted: Tue Feb 19, 2008 8:51 pm Post subject: power seats. |
I installed mine in a hour. You need two wires. Helps if you have the wiring from the seat them self. It ws two wires on mine. I then ran one wire to ground used the seat mount. ANd one wire to the fuse panel.
I used the same gauge wire as came from the seats. Have a spare battery so you can adjust the seats when you mount them to the seats. and to the floor _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Wed Feb 20, 2008 5:07 am Post subject: |
| Neither of my 91 RS' had power seat wires. |
Posted: Fri Feb 22, 2008 4:34 pm Post subject: |
| My '89 didn't have any wires. |
