stormy69 Member
Joined: 13 Feb 2008 Posts: 28 Location: Mtn Home AFB, Idaho
Posted: Thu Feb 14, 2008 1:06 pm Post subject: new guy |
Hey all!,
Shultzy turned me on to this site from 3rdgen. I have an 86 T/A w/305 tpi. i just picked up, its very straight and has zero rust but needs a lot of little things. nickel and dime to death on the way...
I have replaced the inner and outer door handles, hatch lift assy, ignitcion tumbler, CTS, and hatch struts. still need hood struts, hatch lock, headlight prob fix, and the brakes seem weak but it has been sitting for 5 months.. its my first later model f body, i also have a 76 formula 400 and 76 t/a 400.
I am at Mtn Home AFB. Good to be here. i was suprised to find such an active board in Idaho
i am more a ford guy than gm but shultzy said it woul not be held against me
JJ
see me here www.j4jps.com |
'92 camaro boss Member
Posted: Thu Feb 14, 2008 1:13 pm Post subject: |
welcome to the board
your '76 look good? i almost bout one with a 400 in it, ended up fixing my camaro.. |
stormy69 Member
Posted: Thu Feb 14, 2008 1:36 pm Post subject: |
me thinks it looks good it needs paint and some minor rust repair but it was $1k and ended up running with a battery and a starter, has a pretty good black interior, and a new master cyl made it drivable! |
Posted: Thu Feb 14, 2008 1:43 pm Post subject: |
Yea, i'ma fan of them.. had the shaker hood and everthing, 400 turbo trans with a B&M megashifter.. inside was near perfect when i looked at it, just needed paint, and a battery... i think i took the better route fixing my 92 camaro, i'll hopfully have that out within the next week.. |
stormy69 Member
Posted: Thu Feb 14, 2008 1:56 pm Post subject: |
i got to the point on my 86 that i would rather drive it with headlights stuck up than not at all... should be my new daily starting next week. |
Posted: Thu Feb 14, 2008 2:11 pm Post subject: |
Welcome James! That is really cool that you did the GRM challenge, I always have wanted to do that. |
stormy69 Member
Posted: Thu Feb 14, 2008 2:22 pm Post subject: |
twas a blast, if i dont deploy i am going back agian this yr with the stang again and a 72 pinto with a 3.8 supercoupe motor and 5 speed. still deciding on a rearend but i want irs. |
Posted: Thu Feb 14, 2008 2:24 pm Post subject: |
I just need to talk Schultzy into "selling" me his motor for $500. |
stormy69 Member
Posted: Thu Feb 14, 2008 2:31 pm Post subject: |
copy that |
Posted: Thu Feb 14, 2008 5:51 pm Post subject: |
welcome to the crew. not alot of idaho guys one here yet. i think you are the third active member.
stormy; dou you have the remote hatch pop option on your TA? it's the botton on the dash you hit to pop the rear hatch open. you mentioned needing a new hatch lock so i thought i'd ask. i have a hatch pop solenoid i have been trying to give away for a while now... |
stormy69 Member
Posted: Thu Feb 14, 2008 6:58 pm Post subject: |
i actually need the switch and the solenoid for the rear as i would love to have a remote hatch! |
Posted: Thu Feb 14, 2008 9:41 pm Post subject: |
Hey James - welcome to the crew.
BTW, I never promised they wouldn't hold the F*rd thing against you I just thought the odds were pretty good that they wouldn't
Would like to have more guys from Idaho and Eastern Washington active but so far not too many. Spokane has a real active hot rod culture and there are a few guys out there that stay active on the board at least.
Cheers,
Posted: Thu Feb 14, 2008 9:57 pm Post subject: |
stormy69 wrote: | twas a blast, if i dont deploy i am going back agian this yr with the stang again and a 72 pinto with a 3.8 supercoupe motor and 5 speed. still deciding on a rearend but i want irs. |
Welcome to the crew...
The Pinto sounds very much like an ongoing project within the crew using a Chevette with a Camaro 2.8L power plant which he wants to turbo. _________________ 92 Camaro
305 302eater Member
Posted: Fri Feb 15, 2008 8:21 am Post subject: |
Ford sucks! That being said welcome to the crew. _________________ Thirdgenless |
Posted: Fri Feb 15, 2008 8:48 am Post subject: |
305 302eater wrote: | Ford sucks! That being said welcome to the crew. |
welcome, one of my favorite cars ever is the classic bronco my dad used to have. and the cobra i plan on building when i have my midlife crisis. I can't wait
Posted: Fri Feb 15, 2008 10:16 am Post subject: |
welcome to the crew! _________________
stormy69 Member
Posted: Fri Feb 15, 2008 1:19 pm Post subject: |
its good to be here! _________________ 86 Trans Am TPI |
Posted: Fri Feb 15, 2008 4:41 pm Post subject: |
Welcome to the Crew! Glad you took Schultzy's advice and came over. |
Posted: Fri Feb 15, 2008 10:31 pm Post subject: |
you pay shipping and you can have it. you are on your own for a button though.
PM me your address and i'll mail it your way when i get a chance. |
