Red Bird Member
1991 Pontiac Firebird
Posted: Thu Jan 31, 2008 7:48 pm Post subject: Rear end /posi questions |
So my one wheel peel is not cutting it anymore, it was the biggest problem i had at the last autoX. braking good, turn in good, corner entry good, corner exit horrible! i am loosing lots of time having to backpedal and staying out of the throttle trying to keep the one rear tire from going up in smoke coming out of the corners. I picked up a rearend from a v6 5spd bird which should have 3.42 gears, that i plan on installing along with a posi unit. I am not sure what my axle spline count is? Are our 10 bolts 7.5 or 8.5? what series carrier would i need for the gear ratio i plan on installing? I am very clueless about all this, so any answers would be most appreciated. I have been looking for a used posi unit on ebay, but i need to know these specs. I have a pretty tight budget, so im trying to find a used posi unit, that will fit my application and rebuilding it and installing it with the 3.42's _________________ 1991 Firebird L03 T-5 |
Posted: Thu Jan 31, 2008 8:02 pm Post subject: |
The spline count we can't tell you. It will either be 26 spline or 28 spline, it would depend on the year the rear came out of.
If you have 3.42's you will need a 3series carrier.
Our cars are 7.5" or 7.625", but that shouldn't matter as they are basicly the same.
If you are looking for a used posi, I would suggest staying away from the factory auburn style, as they aren't rebuildable (at least not easily, or with easy to find parts). If you can find an Eaton you will be set, but they are scarce for cheap. A Zexel Torsen would do fine, you can find a lot of take-off ones from 4thgens. If you go this route, you have to have 28 spline axles, if you have a 26spline axle right now, you can always hit a junk yard and pick up 28 spline axles for cheap.
--John |
Red Bird Member
Posted: Thu Jan 31, 2008 8:07 pm Post subject: |
Thx alot, the 3.42 rear is out of an 89, my car is a 91. That really cleared things up, just one of the many benefits of the crew:) _________________ 1991 Firebird L03 T-5 |
Posted: Thu Jan 31, 2008 8:14 pm Post subject: |
89, they switched to 28 spline mid year, so that is one that you will have to pull it apart to find out. Worse comes to worse, you 91 will have 28 splines, so if you can find a zexel from a 4thgen, you can use the axles out of your 91 for sure, or you might get lucky and have 28 spines in the 89 also.
--John |
Red Bird Member
Posted: Thu Jan 31, 2008 8:15 pm Post subject: |
Sweet!  _________________ 1991 Firebird L03 T-5 |
Red Bird Member
Posted: Sun Feb 03, 2008 11:19 pm Post subject: |
Yeah, that is a factory auburn. Hopefully it works out. If the clutch packs are slipping, you can't just fix it.
--John |
fiveoformula Member
Posted: Wed Feb 06, 2008 6:13 pm Post subject: |
| Dewey316 wrote: | 89, they switched to 28 spline mid year, so that is one that you will have to pull it apart to find out. Worse comes to worse, you 91 will have 28 splines, so if you can find a zexel from a 4thgen, you can use the axles out of your 91 for sure, or you might get lucky and have 28 spines in the 89 also.
--John |
so my '88 is guaranteed 26 spline axles? (stock) _________________
'88 FORMULA |
Posted: Wed Feb 06, 2008 6:16 pm Post subject: |
| lol, there are no guarantees with these cars. But yes, all 88's should have 26spline axles. |
fiveoformula Member
Posted: Wed Feb 06, 2008 6:24 pm Post subject: |
lol thanks!
how'd you get hooked up with the goods in your rearend john? _________________
'88 FORMULA |
Posted: Wed Feb 06, 2008 6:35 pm Post subject: |
| What do you mean? |
Posted: Wed Feb 06, 2008 7:25 pm Post subject: |
LMAO! Were is the rainbow smiley?
Posted: Wed Feb 06, 2008 7:33 pm Post subject: |
| Schultzy89GTA wrote: | LMAO! Were is the rainbow smiley?
Stop It. |
fiveoformula Member
Posted: Wed Feb 06, 2008 8:08 pm Post subject: |
thats not what I meant! i need to read things after I write...
i mean where did you get your carrier and gears? _________________
'88 FORMULA |
Posted: Wed Feb 06, 2008 8:17 pm Post subject: |
I got the carrier on ebay for $80. (its a bit of a story, but this guy descided to sell his "Eton Lmtd Slip" on ebay, and for some odd reason, I was the only guy bidding on it, lol.
The gears, are good old Richmonds, just ordered them from summit.
--John |
Posted: Wed Feb 06, 2008 9:59 pm Post subject: |
| And there is the key to ebay. Always search mispellings. You'll get a deal. |
fiveoformula Member
Posted: Wed Feb 06, 2008 10:10 pm Post subject: |
would it be better to switch to a 28 spline? looks like theres more options for them _________________
'88 FORMULA |
Posted: Wed Feb 06, 2008 10:29 pm Post subject: |
maybe, the 28 splines are a hair stronger. I am not sure what you mean by more options, you can get a zexel torsen for 28 splines, that is a take off from 4thgens, other than that the other options are about the same. You also have to find the axles if you switch. It is probably going to depend on where you find a deal, if you get a good deal on a 28spline, go for it, and then find the axles to match.
--John |
Red Bird Member
Posted: Thu Feb 07, 2008 9:04 pm Post subject: Got my posi today |
So i got my posi unit today, had a buddy who has some experience with tearing down/rebuilding rears take a look at it, says it looks good, guy from ebay said its out of a 91 formula that was totalled w/85000 miles. cant wait to get it in. Burnouts for breakfast donuts for dinner lol. _________________ 1991 Firebird L03 T-5 |
Red Bird Member
Posted: Fri Feb 08, 2008 6:25 pm Post subject: What is a gov lock posi? |
So i saw a bunch of gov lock posi units on ebay the same time i was bidding on my posi. I did a search on TGO and all i found were posts that said they are crap. does anyone have any experience with these? i almost bid on 1 cuz they are pretty cheap at least on ebay. _________________ 1991 Firebird L03 T-5 |
