Cascade Crew Message Forums
| Does it work? |
| Jan 25th-28th works for me, and I plan to dyno. |
66% |
[ 14 ] |
| It works, but I am not going to dyno |
28% |
[ 6 ] |
| This weekend will not work for me. :-( |
4% |
[ 1 ] |
| Total Votes : 21 |
Mangus Member
Joined: 10 Jan 2004 Posts: 254 Location: @computer in garage (Bothell)
1989 Pontiac Trans Am
Posted: Thu Jan 24, 2008 3:44 pm Post subject: |
| 83Z28BlackBetty wrote: | i can pm you my # and you can call me friday.
~JAKE |
Please do. |
Magman 11sec Club
Joined: 02 Apr 2005 Posts: 217 Location: Whidbey Island
1990 Chevrolet Camaro IROC-Z
Posted: Thu Jan 24, 2008 4:41 pm Post subject: |
Dewey,
Yes, the lifter valley seal, china wall. I always throw the cork stuff out and I laid a nice fat bead of Napa "Even Bead" across the front and back. Drove it last night after a 24 hour cure and today it's leaking. I'm about ready to slap some JB weld over it from the outside and press! _________________ 1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012) |
Posted: Thu Jan 24, 2008 5:01 pm Post subject: |
| is it leaking from corners, I have always used right stuff, and never had an issue. |
Posted: Thu Jan 24, 2008 6:03 pm Post subject: |
The HSR ridge is incredible smooth. You should scuff it up with some fine sand paper and make sure it's BONE dry before assembly. Even bead/right stuff etc will work fine. Lay your beads down, set your gaskets ontop, then add more silicone ontop of the gasket edges at the corner.
Then set the HSR on top and look down the intake ports to make sure the gasket is aligned.
No leaks. |
Magman 11sec Club
Posted: Thu Jan 24, 2008 6:36 pm Post subject: |
I think I may have jumped the gun, I can't find a leak anywhere. Coil/dizzy/plenum are off and the back of the motor is dry. I just might make it yet. I'm putting it back together now then i'll go romp on it a bit and check for leaks. _________________ 1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
