fiveoformula Member
Posted: Wed Jan 16, 2008 4:56 pm Post subject: trans problems |
last year i had to pull out my 700R to get rebuilt, put it back in. drives great.
now i got a nice rattling noise coming from the engine bay...
first i thought it was the AIR pump, then i thought was exhaust, then i got it on the lift today and fired it up, sound like its coming from the tranny, so im thinking torque converter now i gotta pull the trans again!
WHY ME!!!! _________________
'88 FORMULA |
Posted: Wed Jan 16, 2008 5:42 pm Post subject: |
It's not just you man.
Might be a loose converter bolt, or trans bolt. Check those first. |
fiveoformula Member
Posted: Wed Jan 16, 2008 9:59 pm Post subject: |
i hope its just a loose bolt, im having cottman trans do a free check on it tomarrow, well see what they come up with  _________________
'88 FORMULA |
fiveoformula Member
Posted: Thu Jan 17, 2008 4:28 pm Post subject: |
good news, the guy at cottman thinks its just the flex plate cracking or a loose TC bolt, not the actual torque converter _________________
'88 FORMULA |
Posted: Thu Jan 17, 2008 5:52 pm Post subject: |
| fiveoformula wrote: | | good news, the guy at cottman thinks its just the flex plate cracking or a loose TC bolt, not the actual torque converter |
Posted: Thu Jan 17, 2008 9:03 pm Post subject: |
Cottman Trans? You failed to mention any of this to me. Maybe I should have them check my tranny and find the reason why my trans shifts at 3K rpm at WOT. Anyway, there go's your higher stall and lower ET's. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
fiveoformula Member
Posted: Fri Jan 18, 2008 11:22 pm Post subject: |
SOLVED!! i took of the TC bolts today, put some lock-tight on em, and torqued them to 35 pounds... started it up and she puuuured lol no rattle and a big weight off my shoulders. _________________
'88 FORMULA |
