Posted: Tue Jan 01, 2008 4:10 pm Post subject: Productive trips to the yards. & Brakes |
So we have brakes. Just gotta adapt the rubber lines to the hardlines, finish the line lock install and she's set.
Here is what I started with.
Modified Spindle
Just a picture to remind everyone how much stock exhaust pipes suck!
Brakes and cleaned/painted suspension parts.
I had thought about trying to wire wheel out the inside of the fenders.... Um yeah no. That'd take forever.
Tony helped me find a radiator! '82 COROLLA! YEAH BABY/ It's ugly. I'll test it at work this week. It's the ONLY radiator that fit the hole, and had the lower inlet on the drivers side.
Nothing like a half price rear axle. '92 S-10 so it should have 28spline axles. Broke my 8MM socket trying to get the pin bolt out so I can't check it yet. But it's in REALLY good shape, really clean, and has a pretty decent ratio. Not what I was looking for, but I'll take the chance of bigger axles over the ratio. Got some controls arms, panhard, intake bellows also.
41/12=3.416666666666666666666!
Now it's time to look up the best way of welding the spiders. |
Posted: Tue Jan 01, 2008 10:01 pm Post subject: |
looks like some good work!
~JAKE |
Posted: Tue Jan 01, 2008 10:13 pm Post subject: |
Wish I could have scrounged around with you, but too much distance and holiday traffic. Also, my nephew's birthday today was a bit more important Looks like some nice finds and some nice work on the front suspension. |
Posted: Wed Jan 02, 2008 7:50 am Post subject: |
Thanks for the words. It should go together and clean up nicely.
Although I might be puttin the Chevette on hold in favor of the primary car. I have a lead and tested a theory now I need to analyze the results! |
Posted: Wed Jan 02, 2008 8:11 am Post subject: |
No you're not the only one. Also notice the S-10 rear end = 5 bolt pattern, therefor a need to convert the front just for uniformity  |
Posted: Wed Jan 02, 2008 8:15 am Post subject: |
| But how? He mentioned "modified spindle" so did he put a camaro front spindle shaft on it so he could mount the brakes? |
Posted: Wed Jan 02, 2008 5:35 pm Post subject: |
| If you look at the spindle he's made bearing spacers and then tacked them to it. Then used camaro rotors I believe. |
Posted: Wed Jan 02, 2008 6:12 pm Post subject: |
Yep. Camaro/S-10 Front rotors and calipers. Have to mod the caliper brackets a bit but it's just about done. All chevettes (Sub-Compact) came with 4 lug. Ironically the Camaro/S-10 rotor isn't much bigger, nor is the pad, it's just much thicker for the heat dissipation.
I had to notch the castle nut about an 1/8" to get the cotter pin to clear. 1.5" wheel spacers fit the wheels I have. They should be here tomorrow. Then I'm trying to find a 19" brake line that's an IF fitting and not a bubble. Heard rumor on TGO that the '82 type stuff should still be 3/16 IF.
BTW, axles ARE indeed 28 spline. This rear should work our stellar. I get 54" flange to flange, and 55.5" is the max flange to flange to fit my wheels. We'll see what it looks like, or if I need a 1/2" spacer. |
Posted: Thu Jan 03, 2008 6:10 pm Post subject: |
ECU came back from Holley today along with some Wheel Spacers!
WOOT! |
Posted: Thu Jan 03, 2008 6:14 pm Post subject: |
nice.
the 82 fbodys still had american sizes on them. i don't know if they are IF or not. |
Posted: Thu Jan 03, 2008 7:51 pm Post subject: |
| Twilightoptics wrote: | | Although I might be puttin the Chevette on hold in favor of the primary car. I have a lead and tested a theory now I need to analyze the results! |
Did you change lash and test again? Results reveal anything?
