miamivice Member
1982 Pontiac Trans Am
Posted: Wed Jul 14, 2004 10:17 pm Post subject: truck bed liner |
i got a question, there is a car i want. i was contaced about it about a month ago and the owner has been working on it since then trying to get the thing back together. well, anyhow, i learned today that the trunk, floor pans, and engine bay have all be painted w/ truck bed liner. is that gonna cause problems later down the road w/ rust forming underneath or something? anyway to get it off? or should i just walk away and try and find something else _________________
Posted: Wed Jul 14, 2004 10:30 pm Post subject: |
| Depends on if it was used to cover up rust or just to protect it. I've used bedliner on my velle too. It's not really much different then undercoating. Aircraft stripper should remove it. Most bedliner is just very thick urethane paint. |
Midnight Sun Member
Posted: Wed Jul 14, 2004 10:57 pm Post subject: |
Yep... As long as there isn't rust under it you will be fine.
We did the interior of my buddy's Audi rally car with it. And I have done 3 truck beds with it.
Works great. I have it on the underside of my hood, and behind my door panels. _________________
miamivice Member
Posted: Thu Jul 15, 2004 9:54 am Post subject: |
| Quote: | | Depends on if it was used to cover up rust or just to protect it. I've used bedliner on my velle too. It's not really much different then undercoating. Aircraft stripper should remove it. Most bedliner is just very thick urethane paint. |
ok as long as it is something i am able to remove i dont think it should be that much of a problem, just a pain in the azz to take off. _________________
