Posted: Mon Dec 03, 2007 9:44 pm Post subject: Chevette update |
Well since the ol girlfriend is deep in her studies for finals I've had some time to work on it.
All that's left to fire the engine:
-Belt
-Connect wires to the ECU plugs
-Exhaust EGR Block Off Plate
-O2 Bung
Otherwise everything is hooked up. All the gauges and lights function.
Fuel/Boost-Vac/Tach/Water/Oil/Volts. Push button starter, fuel/fan switches. None of the wires are tucked away, since the ECU isn't hooked up yet I don't wanna tie everything together if something is awry. I do have one quirk. When I engage the reverse lights, the rear parking lights come on very dim. Seems like a ground cycling. Chase it down later. I wanna fire this bad boy!
My soldering iron died tonight.
I plan to pick up an aftermarket coil, that's why those wires arent tucked. I'll build some plug wire looms also.
The floor pans aren't actually rusting. It's left over grinding dust :OP Plenty of cleanup after things get tucked.
SO CLOSE!
-Paul |
Posted: Mon Dec 03, 2007 10:17 pm Post subject: |
Saweet! You have been a busy boy the last few days. I particularly like that you are still rocking the tarantula shift knob .
Posted: Mon Dec 03, 2007 10:47 pm Post subject: |
I don't know how you do it. I hate electrical. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
| Nice.... |
Posted: Mon Dec 03, 2007 11:31 pm Post subject: |
| DBL_TKE wrote: | | I don't know how you do it. I hate electrical. |
Nah wiring is easy, welding is what's tough.
Nice work Paul, starting to actually look like a strip car, and not a rusted pile. I like that shifter. |
Posted: Tue Dec 04, 2007 12:20 am Post subject: |
hmm, I'm fine with welding, I always mess up anything with wires though. most of my problems with my car are electrical. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
fiveoformula Member
Posted: Tue Dec 04, 2007 12:23 am Post subject: |
| DBL_TKE wrote: | | hmm, I'm fine with welding, I always mess up anything with wires though. most of my problems with my car are electrical. |
geez then chevy's not a good car for you lol  _________________
'88 FORMULA |
Posted: Tue Dec 04, 2007 12:32 am Post subject: |
| fiveoformula wrote: | | DBL_TKE wrote: | | hmm, I'm fine with welding, I always mess up anything with wires though. most of my problems with my car are electrical. |
geez then chevy's not a good car for you lol  |
don't you ever sleep _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Tue Dec 04, 2007 2:12 am Post subject: |
isn't it a school night. |
Posted: Tue Dec 04, 2007 5:46 am Post subject: |
Awesome Dude!
I never heard from you about Saturday though. _________________
Posted: Tue Dec 04, 2007 7:12 am Post subject: |
| Thanks guys. Hopefully I'll get to finish those few things on wednesday. I'm working all day today and night. She's definitely coming around |
Kage87Z Member
1969 Chevrolet Camaro
Posted: Tue Dec 04, 2007 5:49 pm Post subject: |
| Kage87Z wrote: | | DBL_TKE wrote: | | I don't know how you do it. I hate electrical. |
You should see the box of wiring and junk I've taken OFF the car. !!!! |
Posted: Tue Dec 04, 2007 7:36 pm Post subject: |
Looks good Paul,,,,,,,
For a chevette.  |
Posted: Wed Dec 05, 2007 12:09 am Post subject: |
woot woot! I like!
~JAKE |
