Alternator Help
J-Dog-III
PostPosted: Mon Nov 05, 2007 10:42 am    Post subject: Alternator Help Reply with quote
So i noticed the other night that my volatage was really low so my buddy hopped in and we were going to schmucks like 2 mins away to go buy an alternator. In the middle of the turn lane *poof* alternator goes out end up having to push the car all the way back to the end of a long ass turn lane to park it at an am/pm. SO i bought a alternator that night put it it and it wasnt clocked right. took it back schucks tried clocking it and fucked it up and gave me my money back.
Next day i go to napa and buy an alternator. Put it in and it's barely keeping enought charge on for a surface charge on the battery.
Does anyone know how many amps the Alternator is that i need, because all the ones they keeps selling me arent high enough. BTW im driving a 1986 Iroc 5.0 TPI
PostPosted: Mon Nov 05, 2007 10:49 am    Post subject: Reply with quote
Have you tried a diffrent battery? Are you sure its an alternator issue now? I think stock they are only like 80-90amps, if that. Unless you have something aftermarket that is draining a lot of power, you shouldn't need more than a stock replacement.
PostPosted: Mon Nov 05, 2007 12:09 pm    Post subject: Reply with quote
CS130 should be stock and normally rated at 105 amp. That is to keep up with the demand from power windows and A/C if so equipped. I would also check the battery like John says.
Sellmanb
PostPosted: Mon Nov 05, 2007 3:34 pm    Post subject: Reply with quote
is your serpentine belt stretched? Or if you have V-belts, are they at the right tension?
Make sure that the battery positive and negative bolts are tight as well.
Sounds like something else is going on besides the alternator if you've run through 2 of them now.
PostPosted: Mon Nov 05, 2007 3:43 pm    Post subject: Reply with quote
I'd be looking at wiring as well. Make sure you're getting a proper ignition 12v to the alternator so it's actually 'turning on'
PostPosted: Mon Nov 05, 2007 4:08 pm    Post subject: Reply with quote
I vote battery or connections.
Sellmanb
PostPosted: Mon Nov 05, 2007 6:03 pm    Post subject: Reply with quote
you can run a voltage drop test from the alternator to battery positive terminal. If you have more than .5v's then the positive cable is bad. You should also check the voltage output directly out the back terminal of the alternator, should be around 14v's, this should cross out bad alternator from your list.
If you dont have a digital multimeter, now is the time to buy one, they are an invaluable tool when you start running into electrical problems/driveability problems, or much of any other problems.
PostPosted: Mon Nov 05, 2007 7:04 pm    Post subject: Reply with quote
Truth. I can't even begin to count the number of times I've used mine. I keep it in the car just for that reason.
PostPosted: Tue Nov 06, 2007 11:05 am    Post subject: Reply with quote
usually if the alternator went bad due to a faulty battery. also check and replace the side bolt connecters with new ones they should be bright silver the rubber coating on the side connectors store water there and corrode the conections. if you don't want to replace them right away. a quick fix is just cut the rubber ring off and use a wire wheel on a drill to clean up the connectors and coat them in dielectic greese. other things that could bring on a current drain if your ignition switch isn't properly aligned (which happen to my t/a) and the power ant. relay if power ant is broken and dosen't make noise dosen't mean the power ant. relay is charged disconnect the two sides.
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Tue Nov 06, 2007 6:33 pm    Post subject: Reply with quote
alternators do not charge the battery they maintain a constant voltage and a little more for when you are putting a heavy load on it if your battery died it needs a full charge and a load test to make sure its still good you need to do this soon because a low battery will toast your new alternator ....too much pull
Cadillac of Bellevue
Retail parts sales
vee-six
J-Dog-III
PostPosted: Wed Nov 07, 2007 12:10 am    Post subject: Reply with quote
I know for a fact that its the alternator. I pulled it and had it tested the same night and it was bad. Not it's not the connections and No it's not the battery. I just put a 108 amp alternator in and everythings charging at 13.5Volts
STEEL
PostPosted: Wed Nov 07, 2007 12:15 am    Post subject: Reply with quote
I think what he is saying is that your battery is destroying your alt....
J-Dog-III
PostPosted: Wed Nov 07, 2007 12:30 am    Post subject: Reply with quote
When my dad bought the car the battery was toast . so i went out and bought a brand new one and that was maybe 5-6 months ago
PostPosted: Wed Nov 07, 2007 12:59 am    Post subject: Reply with quote
sounds like your all set. but if THIS alternator goes out soon, look to other things for a solution. Smile
PostPosted: Wed Nov 07, 2007 11:42 am    Post subject: Reply with quote
J-Dog,
Does the car start and run now? if so:
Do your lights flare/dim at all on acceler/Decler?
I'd start checking all the grounds to your charging system and the condition of the wires themselves, make sure they're all tight and the shielding on the wire isn't crimped or damaged.
Did you check the cells on the battery and make sure they have plenty of water (unless they're a "maintainance free" battery)? A load test on the 5-6mo old batter might not be a bad idea, and might save the cost of replacing it if you haven't already.
LB985IROC
PostPosted: Thu Nov 08, 2007 6:28 pm    Post subject: Reply with quote
it doestn matter how new your battery is if it drained way down it needs to be charged it may be charging at 13.5 but once you turn the car off it goes down way lower if its undercharged also try turning on all the accesories ie. heater, lights, stereo and then check it. i see this all the time at work if your alt dies and it drains the battery then it will need to be charged or if its old replaced.
Retail parts sales
vee-six
PostPosted: Thu Nov 08, 2007 7:39 pm    Post subject: Reply with quote
My alternator died on the way to cows last summer, fortunately I was prepared and had another in the car. I was down to 10 volts when I was able to put the spare in, after a jump-start, it took 120 miles of 60+ mph driving to get the voltage up to 13.5.
PostPosted: Thu Nov 08, 2007 9:01 pm    Post subject: Reply with quote
Alternator does charge the battery. Confused
PostPosted: Fri Nov 09, 2007 6:43 am    Post subject: Reply with quote
It probably didn't help with the lights, heater, gadgets, etc you were using on the way down. Very Happy But it'll still take awhile
PostPosted: Fri Nov 09, 2007 7:26 am    Post subject: Reply with quote
I did hold off with the heater for the first 60 or so miles, when I did turn it on, the volt meter dropped back down to 11 volts or so from just over 12. I took the rest of the trip to get up to 13.5.
