a bunch of stufffff!!!!!!
jakemk8706
PostPosted: Sun Nov 04, 2007 8:16 pm    Post subject: a bunch of stufffff!!!!!! Reply with quote
cleaning out the garage and this stuff gots to go.
camaro stuff
1 set of wheels and tires. two of the tires are brand new. than a 1000mi. on them. other two tires are bald. $150 (thats half the price of the tires.)
complete gray plastic cargo area peices. near perfect condition. $50.
passenger front fender. no dents, perfect condition. $35.
sbc stuff
a set of aluminum heads. zz4. dont have the vin number at the moment but i will get it soon. these heads ready to go. they have already seen the machine shop and are all cleaned up. $600
350 block with complete rotating assembly that has also seen the machine shop and is ready for assembly. the block is already painted too. $600
lemme know if anybody want any of this stuff.
gas brake dip dip
PostPosted: Sun Nov 04, 2007 8:51 pm    Post subject: Reply with quote
Any pics of the cargo area pieces?
jakemk8706
PostPosted: Sun Nov 04, 2007 10:06 pm    Post subject: Reply with quote
ya im gonna try to get pics of all that stuff real soon.
just an fyi. if anyone live around ne portland and wants to come take a look/buy Smile im available all the time...for the most part lol
gas brake dip dip
PostPosted: Sun Nov 04, 2007 11:17 pm    Post subject: Reply with quote
BTW, are those cargo area parts from a t-top car, or a car with the hard folding hatch lid?
PostPosted: Mon Nov 05, 2007 12:48 am    Post subject: Reply with quote
are the ZZ4s centerbolt heads?
do they come loaded? (valves, rockers, springs, etc..)
if not; will my stock garbage (valves, rockers, springs, etc..) fit? what size valves are the heads machined for? will my headers bolt up?
i don't know much about heads, but i think i need to freshen the top end on my engine a little, and aluminum sounds like fun.
Very Happy
jakemk8706
PostPosted: Mon Nov 05, 2007 10:34 am    Post subject: Reply with quote
the cargo area peices are from a hard top car. and they had the rear seat shoulder harness, so there are cut outs for that.
as far as the heads, they are centerbolt, they have everything needed to run except the valves and pushrods, the machinist told me that a stock valve train will work just fine with these heads, the springs that are on there are to stock specifications. and yes your headers will bolt up.
gas brake dip dip
PostPosted: Mon Nov 05, 2007 10:47 am    Post subject: Reply with quote
Very Happy
ZZ4's are center bolt.
Not sure with your TPI base if the intake bolt angle will be correct to fit on the heads.
Otherwise it should work.
But GET A NEW CAM if you put these heads on. Your L98 cam will rob any performance potential they might have.
PostPosted: Mon Nov 05, 2007 10:51 am    Post subject: Reply with quote
Tony, I have a feeling it isn't the upper end of your engine that needs refreshing....
I don't think the ZZ4's are vortec though, so his TPI base *should* work, but don't quote me on that one.
--John
PostPosted: Mon Nov 05, 2007 10:59 am    Post subject: Reply with quote
I thought that the ZZ4 heads were essentially the same as the aluminum L98 heads.
nope, vortech has a different bolt angle then the stock TPI base. summit sells a new TPI lower intake that bolts to vortecs, but now we are looking at almost a thousand bucks for a head swap.
john, i have that same feeling, but i gotta try the cheaper stuff before i replace an engine. Smile
PostPosted: Mon Nov 05, 2007 1:24 pm    Post subject: Reply with quote
--John
I knew they weren't vortec's.....I just thought some of the later, and some more modern SBC performance GM heads used a more "straight in" intake bolt angle than previous castings did.
I could be mistaken though.
PostPosted: Mon Nov 05, 2007 1:28 pm    Post subject: Reply with quote
The switch was in 87, so he should be fine.
I don't now that I would do that on his car, he needs a new bottom end, and already has L98 heads, which aren't bad. Also, if the ZZ4 heads, have a 64cc chamber, he will need to get them machined down to 58cc, to even get teh same perfomance as he gets now.
--John
PostPosted: Mon Nov 05, 2007 3:32 pm    Post subject: Reply with quote
Tony. These heads aren't for you right now. If you want to plan an engine. Your rings are shot. You smoke on acceleration.
Start a thread to figure out your motor.
And let this poor guy try to sell his stuff.
jakemk8706
PostPosted: Mon Nov 05, 2007 8:36 pm    Post subject: Reply with quote
ok ill just go to craigslist were people wont be convinced not to buy my stuff. thanks.
gas brake dip dip
PostPosted: Mon Nov 05, 2007 8:42 pm    Post subject: Reply with quote
Dude... That wasn't the point. Those of us that are knowing about Tony's engine, know his engine is toast. We're giving our experiance to him. In a friendly manor. Not to out you a sale.
Don't take it personally.
PostPosted: Mon Nov 05, 2007 9:30 pm    Post subject: Reply with quote
Yeah, we aren't trying to out you of a sale at all, the problem is, we know that his motor is toast, and that he needs to fix that, before spending money on heads. Don't take it the wrong way at all, we are trying to help everyone. If you would like, I can remove all of the responses. I think the ZZ4 heads are a good head, I think they would be great for Tony, if he didn't need a new bottom end. But just like we don't want to take a sale away from you, we don't want another member to buy something, when we know he needs to fix something else first. It is a fine line of trying to look out for both parties.
