BigDaddyVu 12sec Club
Posted: Tue Aug 21, 2007 11:39 am Post subject: did some up grades on my turbo z28 |
i heads machined for bolt on studs and guide plates and installed full roller rockers, harden push rods, and a rocker stud girdle. I also replaced the holley 750 with a mighty demon 750 BT with runs better than the old holley. i ran 12.50's when i cranked up the boost up to 15 psi but keep blowing the hoses off when i hit third gear 2/3rds of the track. so i replaced a couple of couplers and having 2 more being custom made by a local turbo hose company (manufacturer of hks, turbonetics, and turbo hoses) also install a A/F gauge one the pillar and a fuel gauge mounted in the hood scoop (NHRA legal)
Posted: Tue Aug 21, 2007 11:47 am Post subject: |
holy shizle that thing is so sick! it makes me want to do that!
how hard is it to drive?
Posted: Tue Aug 21, 2007 11:54 am Post subject: |
| it drive like any normal f-body but when i put the hammer down (while rolling) one of two things happen. front likes to come up or go side ways. but it gets really good gas miliage if i stay out of the boost. |
Posted: Tue Aug 21, 2007 11:57 am Post subject: |
| But it is impossiple to drive on wet pavement. like i was driving on ice. |
Sellmanb Member
Posted: Tue Aug 21, 2007 6:35 pm Post subject: |
BigDaddyVu has "666" posts .
That car is just mean man. What size rear tires on the back and what model/make ? |
scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Wed Aug 22, 2007 11:59 am Post subject: wow |
that looks sweet.
Great work.
I can tell you love that car, it is sweet.
That makes me want to hurry up and get our engine done!!!
scott |
Brizio Member
Joined: 14 Jul 2007 Posts: 111 Location: Around the World
1985 Chevrolet Camaro IROC-Z
Posted: Thu Aug 23, 2007 8:49 am Post subject: |
| Great Job!!! make sone videos!!! |
Posted: Thu Aug 23, 2007 3:23 pm Post subject: |
Damn! Every time I think I've got the turbo bug out of my system I see something badass like this and I wanna do it too!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Fri Aug 24, 2007 9:04 am Post subject: |
well... i gotta break the "666" posts.
if you price the parts in the engine compartment on the car its really a cheap build. a stock well broken-in engine will do. |
Posted: Fri Aug 24, 2007 9:09 pm Post subject: |
I have grand visions of turboing my 2.8L but a small block would probably be more realistic. The 305 in the Z is getting massive blow-by and thus probably isn't a worthy candidate for forced induction either.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Aug 25, 2007 1:57 am Post subject: |
| re-ring it. |
Posted: Sat Aug 25, 2007 11:54 am Post subject: |
I'm of the belief that if the 305 ever comes out of the engine bay then a larger engine will go back in.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Aug 25, 2007 7:12 pm Post subject: |
well one guy is finished coping my setup on his regal looks identical to mine for the exception hes using a larger turbo a borg warner s400. any one of you guys have plans of building on soon?
I have been learning more about turbo basics and setups on this site if your curious about turbo charging anything. http://www.theturboforums.com/smf/index.php |
Posted: Tue Aug 28, 2007 1:20 pm Post subject: |
| Sellmanb wrote: | BigDaddyVu has "666" posts .
their P275/60 r15 grand am's from les S |
izcain 9sec Club
Posted: Tue Aug 28, 2007 9:39 pm Post subject: |
are those 12.50's with the street tires? thats really good for street tires if it is!!! Im lovin the car! _________________
9.17 @ 148 |
Posted: Tue Aug 28, 2007 10:58 pm Post subject: |
| yes it is everybody at the track thought it was funny i could do that without spinning them but i need to put slicks in the back if i want to go faster but i don't know if i want too. if i break the 12.50's i am required to wear a helmet. and if i wanna go faster i have to add 2 more points to my roll cage and use 5 point saftey belt. i just want a consistant car i could race for awhile. |
Posted: Mon Sep 17, 2007 7:13 pm Post subject: |
| Is there some sort of brace or bracket that the turbo sits on? |
Posted: Wed Sep 19, 2007 9:12 pm Post subject: |
| yes there is a bracket (1/2"angle iron)welded underneath the turbo flange(where it Y's to the flange) to the bolt hole where your smog pump bolts too on the block. |
Posted: Wed Sep 19, 2007 9:45 pm Post subject: |
| Have a picture of the bracket? |
