Posted: Mon Aug 20, 2007 10:18 pm Post subject: vortec heads |
So i found a set of Vortec heads pretty cheap with low miles.
1.94/1.5, 64cc chamber, 170cc intake port
$175 for both
I'm not sure what these heads go for normally and what they are rated to do to a stock 350 without after market heads. any thoughts?
Posted: Tue Aug 21, 2007 12:04 am Post subject: |
Do you have the casting #'s? They could be the Vortec 305 heads.
Also the guy's phone number....because I think I'd like to buy em before you do
$175 is pretty good for a pair, even if they have to go to the machine shop.
How they'll perform, is based on a lot of factors, your CR, cam profile, RPM operating range, Pistons, Timing, etc.....
Assuming they're 64cc you might be looking about an extra 30-40hp or so. _________________
Posted: Tue Aug 21, 2007 6:58 am Post subject: |
thanks for the input chris, I decided against them and they went to another person in line behind me.
I need to sit down and fully plan out what i want out of my car before I go off spending money on heads and stuff. Besides, there are plenty of other things this car NEEDS before I go buying something i want. like a new rear-end, the wiring mess, and SFC's
Posted: Tue Aug 21, 2007 8:01 am Post subject: |
Do you know what kind of pistons you have? You may want to figure out your bore/stroke and piston volume so you can figure out what kind of compression you'll get with x heads.
You know jake, I'm not that far away and I'm good with wiring. i would't mind helping a hand one of these weekends to clean up your wiring. |
BigDaddyVu 12sec Club
Posted: Tue Aug 21, 2007 11:50 am Post subject: |
you should get em and buy my intake made for vortec heads but remember if its a factory vortec heads the can only use them on 86 and up one piece seal.
impluse buy my intake |
Posted: Tue Aug 21, 2007 12:01 pm Post subject: |
| +1 |
Posted: Tue Aug 21, 2007 3:52 pm Post subject: |
| BigDaddyVu wrote: | you should get em and buy my intake made for vortec heads but remember if its a factory vortec heads the can only use them on 86 and up one piece seal.
Why?
I'm pretty sure it doesn't matter, any Gen I small block can use vortec heads. |
Posted: Tue Aug 21, 2007 3:54 pm Post subject: |
No guideplates for pushrods, so you either need a roller block, or you need to have a machine shop do the work on the stud bosses to attach guideplates.
--John |
Posted: Tue Aug 21, 2007 5:25 pm Post subject: |
| Dewey316 wrote: | No guideplates for pushrods, so you either need a roller block, or you need to have a machine shop do the work on the stud bosses to attach guideplates.
--John |
Or you just run guided rockers like i am on the pickup. |
Posted: Tue Aug 21, 2007 6:29 pm Post subject: |
| chevymad wrote: | | Dewey316 wrote: | No guideplates for pushrods, so you either need a roller block, or you need to have a machine shop do the work on the stud bosses to attach guideplates.
--John |
Yup |
