Posted: Thu Jun 07, 2007 7:41 am Post subject: FS: The last of my automatic stuff, plus other junk |
--Automatic trans temp gauge. Autometer with electrical sender. Bought it from Paul and never used it since I am swapping trannies. Any questions about it should be sent his way. $25 shipped.
--700R4 style shifter with cable. Knob is a little worn, but in great shape. $20
--Shift plate. Four speed style (PRN[D]D21). SOLD
-Speedometer cable. Works fine. Came out of an '87, no idea what years it would fit. Make offer.
--Auto-style pedals. Good shape but the rubber brake pad is shot. $15
--Cruise harness from LT1 style clutch & brake pedals. My cruise is gone, so I don't need them, but they would be good for anyone looking to make their cruise control work after a T56 swap. Make offer.
--Aftermarket trans fluid cooler. No idea what brand. Only has a few thousand miles. No hoses or clamps, but I do have the fitting so you can attach the rubber line to your radiator. $20
--Never-used 700R4 torque converter. Got it from a guy along with some other parts, he told me it stalled at around 2400 and was a non-lockup. Never been installed, just sat around for a few years. Make offer.
--Core 700R4. No third our fourth gear. Has shift kit and vette servo. Make offer.
--Stock 700R4 flexplate. $10
--Stock T56 shifter, stick, and knob. Knob is leather, but badly worn. Small split in the rubber cover, otherwise fine. $25 shipped
--T56 stock rubber tranny mount. Looks relativly new. Make offer.
--U-bolt for T56 clutch master cylinder. Bolts LT1-style master to the pedals through the firewall. $8
--Stock Torque arm mount and catalytic converter bracket for 700R4. Make offer
--Oil cooler "sandwich" with bolts and insert, but no lines to the radiator. Fits between the filter and the pump on IROC's. Make an offer
kurfbird Member
Posted: Thu Jun 07, 2007 7:49 am Post subject: Shifter |
Can I get some Pics to kurfisb@msn.com
What did it come out of?? _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Thu Jun 07, 2007 2:07 pm Post subject: |
| Will take pics later this afternoon and get them out to you. Everything came out of an 1987 L98 IROC unless otherwise noted. |
BigBoi4Lyph Member
Joined: 10 Jun 2007 Posts: 233 Location: Olympia, Washington
Posted: Sun Jul 01, 2007 2:22 pm Post subject: |
Hey do you happen to have the shifter plate? with the ash tray and everything attatched.
thanks _________________ 87 Camaro Z28 - Iroc-Z |
Posted: Sun Jul 01, 2007 3:12 pm Post subject: |
I was kind of leaning towards keeping the ash tray since no one has ever smoked in the car, and it's kinda virgin and not all ashy inside. However I might let it go with the plate. |
BigBoi4Lyph Member
Posted: Sun Jul 01, 2007 3:33 pm Post subject: |
ohh its all one peice tho right or ate you taling about the removable park of the ash tray? i have that peice im just looking for the plate that goes from the radio to the center consol lid its all one peice and has the P N D 3 2 1
pm sent interested and could pickup today. call the number i sent you in pm _________________ 87 Camaro Z28 - Iroc-Z |
Posted: Sun Jul 01, 2007 6:42 pm Post subject: |
| It's in a lot of peices, actually. The main ones being the plate, the lid, and the tray itself. The entire plate assembly does come apart though. |
scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Mon Jul 02, 2007 9:33 am Post subject: |
got a pic?
what size? |
BigBoi4Lyph Member
Posted: Mon Jul 02, 2007 2:44 pm Post subject: |
i would like the whole peice. how much for it. i can pick it up today if your avalibtle i would really like to get it asap as mine is broken and the whole peice moves with my shifter. lol thanks _________________ 87 Camaro Z28 - Iroc-Z |
Posted: Mon Jul 02, 2007 8:06 pm Post subject: |
| scott in wa. wrote: | Automatic trans temp gauge. Autometer with electrical sender. Bought it from Paul and never used it since I am swapping trannies. Any questions about it should be sent his way. $25 shipped.
got a pic?
what size? |
Yup...
It's standard 2 1/16 in. |
BigBoi4Lyph Member
Posted: Mon Jul 02, 2007 8:28 pm Post subject: |
Thanks alot for the shifter plate. works great. looks much better. After you get your car up and going we will have to head out to pacific raceways. _________________ 87 Camaro Z28 - Iroc-Z |
