Couple of hours on the park lights
PostPosted: Sun Jun 10, 2007 9:26 pm    Post subject: Couple of hours on the park lights Reply with quote
I spent a couple of hours on the park lights of the 89 today. Removed the housings, cleaned the lenses, rinsed out the insides. Before I put them back in, I cut a notch in the bumper to line up with the vent hole in the light. Now the vent isn't blocked off any more to collect the moisture and dirt. They're not perfect, but look much better and will do until either I replace them or upgrade my headlights and use the clear ones I have lying around Laughing
What they looked like when I bought the car last August...
After a couple of hours today....
PostPosted: Sun Jun 10, 2007 9:50 pm    Post subject: Reply with quote
I'm gonna need to do that myself pretty soon. Any special cleaners to use on them, or just water and a rag?
PostPosted: Sun Jun 10, 2007 10:00 pm    Post subject: Reply with quote
I used Meguiar's Clear Plastic Polish and Clear Plastic Cleaner for the outside. Could have done some wet sanding too, there are some pits in the lenses yet, but it looks so much better than before.
PostPosted: Sun Jun 10, 2007 10:14 pm    Post subject: Reply with quote
How'd you get the inside so darn clean? Mine look super nasty like that
PostPosted: Sun Jun 10, 2007 10:17 pm    Post subject: Reply with quote
Actually, they're not that clean on the inside. All I could do was to rinse them out with high pressure water from the garden hose and shake them out. There are still small bits of stuff in them between the diffuser and the lens.
PostPosted: Mon Jun 11, 2007 12:17 am    Post subject: Reply with quote
you can use compressed air and a shop vac
PostPosted: Mon Jun 11, 2007 12:22 am    Post subject: Reply with quote
Wasn't there a slight explosion involved with that BigDaddy? Surprised
PostPosted: Mon Jun 11, 2007 10:08 am    Post subject: Reply with quote
How did you get the front lense off? I've done this before but I had to cut it.
PostPosted: Mon Jun 11, 2007 10:14 am    Post subject: Reply with quote
Never took the assembly apart, just used th hose to clean the inside as best I could Wink
PostPosted: Mon Jun 11, 2007 12:09 pm    Post subject: Reply with quote
I made some clears from my stock ones. The front lense does not come off easy.. in fact, I dont recommend taking the front lense off.
Guess I need to post pics of mine now that I opened the can o worms huh?
gonna have to be later tonight.
PostPosted: Mon Jun 11, 2007 12:58 pm    Post subject: Reply with quote
if it blows up you don't have to worry about it anymore
PostPosted: Mon Jun 11, 2007 12:59 pm    Post subject: Reply with quote
just try not to end up in the E.R.
PostPosted: Mon Jun 11, 2007 6:55 pm    Post subject: Reply with quote
Now that's the attitude to have! Laughing
PostPosted: Tue Jun 12, 2007 4:00 pm    Post subject: Reply with quote
Heres mine. Yes, these are factory gm lights.
[/img]
PostPosted: Tue Jun 12, 2007 4:49 pm    Post subject: Reply with quote
Man I wish mine would look even like that. Mine are horrible. I've tried cleaning, toothpaste, and wet sanding and you still can barely see through the front lens. I''l pick up some plastic polish and see what that'll do.
PostPosted: Tue Jun 12, 2007 8:50 pm    Post subject: Reply with quote
I didn't know you did the clear mod!?!?!
PostPosted: Tue Jun 12, 2007 8:53 pm    Post subject: Reply with quote
I like that, I may have to do it at some point. Or maybe I'll get the diamond cut ones like Al had at one point. First is the HID stuff. Freakin true bi-xenon projectors are bloody expensive.
PostPosted: Wed Jun 13, 2007 4:00 am    Post subject: Reply with quote
I sent a txt msg to your phone with a pic attached after I did them. you must not have gotten it.
I had a weekend to burn, so I did this. Its a real PITA, I would recommend paying the 60 for the real clears.
