scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Fri May 18, 2007 7:01 am Post subject: Commander 950 |
Looks like we are going to the dark side, like some of you have.
Ready to spend our money.....
We are ready to buy this 950 commander.
Looks like it’s about 950 bucks from. best price????
http://www.sdparts.com/product/H950-101/198592GMTPICommander950EnginemanagementSystems.aspx
So is this all I need or do I have to order more stuff????
Doesn’t say what it comes with,
Some one bought this a while ago, how did the install go???
Did you have to buy anything else?
Thanks
Scott |
Posted: Fri May 18, 2007 8:48 am Post subject: |
That should come with the ECM, MAT sensor, MAP sensor, Heated O2 Narrow Band Sensor, Wiring Harness, o2 Bung, serial>ecm cable, and some other misc pieces.
Didn't have to buy a thing. Gutted my and Mike's old ecms and put our C950 in there. Takes a little trimming, but you can mount the thing right where the factory comp went. You use the outer shell that has the nipple and two mounting holes.
You retain your stock TPS, IAC, Coolant Temp, etc.
There are about 4-7 wires to hook up plus main battery depending on your options. IE: AC, Shift light, automatic park/neutral signal, cooling fans.
Have fun with it! It's a blast to use! |
scott in wa. Member
Posted: Fri May 18, 2007 9:01 am Post subject: so |
So it comes with instructions as well?
you just gutted the old ecm and mounted this into the steel box???
what about hooking up a computer to this thing?
is had a port or somthing? can you do data logs as well?
cool. |
Posted: Fri May 18, 2007 9:10 am Post subject: |
Comes with a very handy instruction book on how to use the software AND how to tune your car. You can find it on holley's website.
That's correct on the ecm box. Keep it's guts in the inside piece. I just used the outer shell.
The serial>ECM cable that it comes with hooks from the ecm to your laptop's serial port. If you don't have a serial port you can get a serial>USB adapter from most electronics stores for about $30.
You can data log yes. Best way though is to have your kid drive while you tune. Just plug in, change a number, done. |
Posted: Fri May 18, 2007 9:19 am Post subject: |
| Twilightoptics wrote: | | ... You use the outer shell that has the nipple and two mounting holes... |
hehe, he said 'nipple'
Scott, like Paul said you can download the tuning guide from Holley's website if you want to get an advance look at what is involved for the install and tuning.
