scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Thu Apr 26, 2007 9:08 am Post subject: I need, we have an 88 vert |
Passenger side door/electric windows and locks
Passenger side front fender
Ground effect, 91/92 for the front end and doors.
And
The front end nose piece that has the two fog lights up front. I don't know what model or year that is.
How about a new/ nice Vert top, with the glass rear window as well.
thanks
scott |
90droptoproc Member
Posted: Thu Apr 26, 2007 2:43 pm Post subject: Re: I need, we have an 88 vert |
| scott in wa. wrote: | How about a new/ nice Vert top, with the glass rear window as well.
thanks
scott |
BWAHAHAHAHAHAHAHAHAH!!!!!! good luck on that one
my wife lucked out once and got me my top for the iroc, but it had been taken off the frame allready so it was a pain to swap over, the ground effects you are looking for either have to be from a vert or have to be modifies to fit around the sfc, the same with the fender. The door is a direct swap off any other thirdgen, vert or not
I will keep an eye out for these parts for ya out here
Rich _________________
scott in wa. Member
Posted: Thu Apr 26, 2007 6:33 pm Post subject: stuff |
So the door is the same.
front right fender,...NOT?????
Or is it somthing like cutting a little underneith??????
same with the ground effect???????
I need more detailed info.
thanks
scott |
Posted: Thu Apr 26, 2007 9:01 pm Post subject: |
Both GFX and fenders can be adapted from hard/ttop cars to work on a vert. Either just cutting or cutting and swapping the fender bracket. _________________
90droptoproc Member
Posted: Fri Apr 27, 2007 12:45 am Post subject: |
ya what Ian said, just zipcut the lower bit of the fender off and rivewt or weld on the tab, and the grf need the whole botom edge cut out, I have done it for afew now _________________
