Posted: Sun Apr 22, 2007 1:35 pm Post subject: HVAC controller |
Anyone have the mode selector switch for the Camaro HVAC controller? Mine went out and was the real culprit for my failing blower motor. I dis-assembled the switch, removed the contacts, turned over the (for lack of a better term) wafer, re-installed the contacts and put the switch back together. Now my blower works, but the repositioning of the contacts put the bad one in a different place, now the A/C doesn't work.
The part I'm looking for is operated by the slider on the front panel. _________________ 92 Camaro
kurfbird Member
Posted: Sun Apr 22, 2007 1:56 pm Post subject: A/C Controller |
I have a A/C controller. Actually the whole set up with wiring. Make and offer _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
90droptoproc Member
Posted: Sun Apr 22, 2007 3:12 pm Post subject: |
do you need a/c or non a/c?, I can send you out a new control panel for shipping cost.
I have a dozen or so laying around _________________
Posted: Sun Apr 22, 2007 3:49 pm Post subject: |
It's for A/C, but I only need the rotary switch behind the control panel. Really don't want to get the whole panel for just the switch.
Not an emergency yet, my blower works. I forgot to look in the interiors when I was at the JY yesterday. _________________ 92 Camaro
Posted: Sat Apr 28, 2007 2:22 pm Post subject: |
Found one today in good shape. Cleaned up nicely and works fine. Thanks for the offers. _________________ 92 Camaro
