305 302eater Member
Posted: Tue Apr 10, 2007 10:39 pm Post subject: |
| Which housings did you go with? Since we both know that the cheapo's off ebay suck for H4. |
305 302eater Member
Posted: Wed Apr 11, 2007 8:04 am Post subject: |
I kept the cheap ebay housings. The hids work in those housings. I bought the more expencive h4 hi/lo hid kit so the inner headlights dont come on anymore. so the inner headlights will just be for the halo lights only. I need to find a color of fog that matches my headlights now though. _________________ Thirdgenless |
mrpopo573 Member
Posted: Wed Apr 11, 2007 11:05 am Post subject: |
WOW DUDE _________________
2000 Maxima SE 5 Speed VQ30
305 302eater Member
Posted: Wed Apr 11, 2007 3:18 pm Post subject: |
| mrpopo573 wrote: | | WOW DUDE |
Wait till you see them in person. So much better then what I had. I am very happy. _________________ Thirdgenless |
Posted: Wed Apr 11, 2007 8:41 pm Post subject: |
| You should look into retro'ing projectors. A night and day difference between freeform housings. |
305 302eater Member
Posted: Thu Apr 12, 2007 9:49 am Post subject: |
I haven't been able to find anyone that makes a 4x6 projecter housing anymore. I will keep looking though. That is what i have wanted to do for a long time.  _________________ Thirdgenless |
Posted: Thu Apr 12, 2007 9:50 am Post subject: |
| Can you go HID and have all 4 lights work like factory? |
Posted: Thu Apr 12, 2007 10:23 am Post subject: |
Since they use a ballast which needs to warm up to get full power, wiring like factory isn't practical. The ballast won't warm up fast enogh to make the high beams useable when you want them. _________________ 92 Camaro
305 302eater Member
Posted: Thu Apr 12, 2007 5:11 pm Post subject: |
| Twilightoptics wrote: | | Can you go HID and have all 4 lights work like factory? |
Well yes and no the ones i got are hi/lo h4 in the same bulb, they call them a slider bulb. So when i hooked them up and tuned the brights on the inner 2 still worked. But they looked out of place with the hids so i unpluged them. Didn't need them anyways. But to answer the question they still function like stock. _________________ Thirdgenless |
305 302eater Member
Posted: Thu Apr 12, 2007 5:14 pm Post subject: |
| Al Hasse wrote: | | Since they use a ballast which needs to warm up to get full power, wiring like factory isn't practical. The ballast won't warm up fast enogh to make the high beams useable when you want them. |
These ones work fine. Can see anything with these. I just pull back and the the high beams are deffenetly on. They are cool.  _________________ Thirdgenless |
izcain 9sec Club
Posted: Thu Apr 12, 2007 11:22 pm Post subject: |
Sweet man! I would have done mine sooner but to many other things in the works right now hopefully I will get the HID's rigged up soon! _________________
9.17 @ 148 |
Posted: Fri Apr 13, 2007 7:08 pm Post subject: |
If anything it'd be easiest (maybe not cheapest) to wire all four to be high/lows. |
aximil New Member
Joined: 18 Apr 2007 Posts: 13 Location: Bellingham/Custer/Poulsbo
1989 Chevrolet Camaro IROC-Z
Posted: Fri Apr 20, 2007 12:39 am Post subject: |
actually you don't want all four light on when you are in low beam mode because i asked a cop about my headlights (right after he gave me a reckless driving ticket ) and he said that you can onlt have two sets of headlights on legally when you have you highbeams on, for the low beams you can only have one set on. (hi, I'm new by the way, nice to meet you all) _________________ 1989 IROC-Z Camaro
305 TPI w/T5 (non-worldclass because of previous owner.....blown it up twice!!) |
Posted: Fri Apr 20, 2007 6:09 am Post subject: |
Sounds like a nice car you've got aximil.
Actually, you can have a second set on as long as you call them driving lights or something like that and not headlights.  |
Posted: Fri Apr 20, 2007 8:42 am Post subject: |
You can have on two sets of bright lights at a time. Hi + Lo beams equals two sets. Thats why factory fog and/or driving lights are disabled when the high beams are turned on. _________________ 92 Camaro
305 302eater Member
Posted: Fri Apr 20, 2007 8:44 am Post subject: |
| aximil wrote: | actually you don't want all four light on when you are in low beam mode because i asked a cop about my headlights (right after he gave me a reckless driving ticket ) and he said that you can onlt have two sets of headlights on legally when you have you highbeams on, for the low beams you can only have one set on. (hi, I'm new by the way, nice to meet you all) |
Hey martin whats up. Ya i've been told the same thing you can have 4 lights on as long as 2 of them are below your headlights but i'm sure there is a rcw hidden that says else wise. _________________ Thirdgenless |
Posted: Fri Apr 20, 2007 8:51 am Post subject: |
| Al Hasse wrote: | | You can have on two sets of bright lights at a time. Hi + Lo beams equals two sets. Thats why factory fog and/or driving lights are disabled when the high beams are turned on. |
Heheheh yeah I fixed that. I like having six lights on when I'm on the twisty mountain road in the pitch black like a frieght train! |
Posted: Fri Apr 20, 2007 9:38 am Post subject: |
Heh, I have a plan for doing HID's the right way. I've been doing a lot of research on light patterns and diffrent HID tech. I have everything figured out now....just need to wait until I get back from Africa, so I can drop the coin to the D2R (true bi-xenon) bulbs and balists and everthing I need to keep the light pattern and aiming right.
I am sure you will see something on it this fall..... |
