This is our hot car, well it was on fire...
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Fri Apr 20, 2007 7:20 am    Post subject: This is our hot car, well it was on fire... Reply with quote
Melted, I think if you double click these pic a couple time you will be taken to my pic page and can view them bigger, in much better horrific detail...
Melted form back to front, to break booster, to dual fans, to harness.
From a loose fuel fitting on the stainless lines.
The rubber in the stainless lines were almost completely melted. If they would have caught fire I believe it would have gotten to the full gas tank.
we caught it just in time. Yes we can fix it and make her better..LOL....
pathology knight
PostPosted: Fri Apr 20, 2007 7:41 am    Post subject: Reply with quote
dang it!
nothing but red x's again. So mad I can't see straight
we all gotta start somewhere....
scott in wa.
PostPosted: Fri Apr 20, 2007 7:53 am    Post subject: ya Reply with quote
Ya this thing got hot,
It even melted both strut caps.....check it out.
Motor ready to come out., will replace the cam, maybe some more head work, I want more lift maybe aroung .550 so I will have to have them machined a little, If I try and do that now I will have coil bind.
Oh ya, powder coating is almost bullet proof!!!!
PostPosted: Fri Apr 20, 2007 8:09 am    Post subject: Reply with quote
Wow scott, it doesn't seem like it but you guys actually got really lucky. Nothing but the wires and plastic seem to be damaged.
scott in wa.
PostPosted: Fri Apr 20, 2007 8:12 am    Post subject: yep Reply with quote
Ya pretty much.
Iruined a shirt I had on, from all the tears that were streaming down my face!!!LOL....
PostPosted: Fri Apr 20, 2007 8:36 am    Post subject: Reply with quote
Crying or Very sad
That definitely sucks man.
PostPosted: Fri Apr 20, 2007 9:40 am    Post subject: Reply with quote
remeber the moto Scott.
"bigger, faster, stronger!"
I didn't realise there was that much damage, that is going to be a real mess. But, hey you will have a practicly new car when you are done!
PostPosted: Fri Apr 20, 2007 2:26 pm    Post subject: Reply with quote
That sure is a sore sight. There's no real damage to the actual engine is there? Good thing you caught it in time. maybe an excuse for an A/C delete box then, eh?
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Fri Apr 20, 2007 4:46 pm    Post subject: Reply with quote
man my IROC did that once but it was from the dip stick missing the o-ring and oil got on the headers and all over the harness on the passenger side and one time i was roasting the tires and woosh the car filled wiht smoke and i didnt knwo it was on fire then about a mile later it was still smoking and i popped the hood and damn its on fire but i managed to get the fire extinguisher on it and saved the car but the heater box was done for lol
Cadillac of Bellevue
Retail parts sales
vee-six
scott in wa.
PostPosted: Sat Apr 21, 2007 9:30 am    Post subject: Reply with quote
yep,
got it in the mail yesterday, hope it fits, its a metal one.
Motor is ok, but everything else, is bar-beee-qued......
motor coming apart anyway.
I can't go much farther on the motor, its the stock crank and rods.
so maybe some head work, a different cam, and a quite gear drive.
Ya, a gear drive, Man I gota try it, and see what the knock counts do.
Maybe nothing.
Shweet.
scott
PostPosted: Sat Apr 21, 2007 12:12 pm    Post subject: Reply with quote
[quote="scott in wa."]
I'm running a stock crank and rods on a 2 bolt main 350.
PostPosted: Sat Apr 21, 2007 12:34 pm    Post subject: Reply with quote
General concensus is that stock crank and rods can handle 500 Hp at 7000 rpm. That means more power at lower speed. I wouldn't worry about them too much as long as the assembly is well prepared and balanced. This craze about forged rods and crank is over done. In fact, a stock crank in many cases is more durable for street driving.
Kage87Z
1969 Chevrolet Camaro
PostPosted: Sat Apr 21, 2007 2:11 pm    Post subject: Reply with quote
Mine is still sick from 2 years ago... doing the same thing. Arced against the dipstick tube with the 12 vote cable to the starter.
Sigh.
Todd Beamer - 9/11
Never Forget
PostPosted: Sat Apr 21, 2007 2:30 pm    Post subject: Reply with quote
I do have ARP rod bolts and polished rods :O)
Balancing is a huge factor. When I put mine together the first time I didn't balance and it was quite the vibration station. It's so smooth now with a bigger cam!
If i did it the same again id do main studs. other than that im happy camper.
