scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Thu Mar 29, 2007 9:42 am Post subject: Solvent tank, degreaser |
I picked up and old KleeenFlow parts washer last night.
Its maybe from the 60's maybe takes 20 gal .Iam wanting to put some degreaser in it but do not know what to get.
I want really good stuff, nothing that kinda works good.
Do you guys have any idea what to use?
Where can I get it?
thanks
scott |
NHRA427 Member
Posted: Thu Mar 29, 2007 3:35 pm Post subject: |
| We use solvent |
mrpopo573 Member
Posted: Thu Mar 29, 2007 4:01 pm Post subject: |
We personally either buy bulk solvent from the local parts house, OR for degreaser I strongly recommend OIL EATER, you can buy in 5 gallon buckets from Costco.
Awesome stuff. Not Skin Friendly.  _________________
2000 Maxima SE 5 Speed VQ30
Posted: Thu Mar 29, 2007 9:04 pm Post subject: |
| mrpopo573 wrote: | We personally either buy bulk solvent from the local parts house, OR for degreaser I strongly recommend OIL EATER, you can buy in 5 gallon buckets from Costco.
Awesome stuff. Not Skin Friendly.  |
I sell the 5 gallon buckets of the stuff at schucks. Good stuff! |
scott in wa. Member
Posted: Fri Mar 30, 2007 11:41 am Post subject: so |
So this stuff is water base, right??
Have you ever had to drain and refill or just keep adding more??
I think its like 54 bucks for 5 gal.
takes the skin off of your hands ??? hummm sound like its good stuff. |
scott in wa. Member
Posted: Fri Mar 30, 2007 12:28 pm Post subject: |
whats that???
????Piezo-Electric Vibrating Generator??????
Basis:
1. A thin piece of metal, plastic, cloth or paper ribbon/flag "flaps" in the wind. The stronger the wind the more it flaps at a given frequency.
2. Piezo-Electric elements turn mechanical strain into electrical potential (voltage).
Now the idea:
A piezo-electric element that is attached to a thin metal strip will generate a voltage as it flaps back and forth due to wind. The stronger the wind, the higher the "flap" frequency, and therefore the larger the voltage generated.
Posted: Fri Mar 30, 2007 12:43 pm Post subject: |
Uh, also run backwards they will produce ultrasonic frequencies that will help break up dirt and grease from engine parts. Combined with soapy water, it will "degrease" parts without toxic products. _________________ E30
