Posted: Wed Mar 28, 2007 4:53 pm Post subject: Quasi-Traction's personal checklist for Cows VI. |
1) Get a rear brake proportioning valve
2) Resurface Rear rotors, replace rear pads
3) Bleed brakes
4) Get wipers working
5) Replace passenger E-brake cable.
6) Put Rear sway bar back on
7) get new tags/registration
8) Install "temporary" exhaust (likely a couple short 3" pipes to glasspacks)
9) Get rear tires rebalanced, checked for leaks
I have roughly two months.....providing nothing catastrophic happens...I should be good to roll the berlinetta to skamokawa! _________________
Posted: Wed Mar 28, 2007 4:56 pm Post subject: |
Um... yeah... Fundage provided that's like a weekend job there dude.
When I put the wilwood prop valve in, you can have mind.
Just going to roll Mr. blowby for now? |
Posted: Wed Mar 28, 2007 4:58 pm Post subject: |
| Pff, get a couple of us over there, and that is a lazy afternoon with some beer. |
Posted: Wed Mar 28, 2007 5:15 pm Post subject: |
if this gets done relatively soon (I.e, within a weekend or two...) fundage will definately be there.
I'm itching to get this thing on the road ASAP.
paul, what's the ETA for the wilwood? I'd like an adjustable, but right now I just want something to get me by...and free is an offer I will not refuse.
The wipers are the biggest thing I'll need help with....I'm still kind of a dead-head at troubleshooting with electrical.
yeah, I'll just put a breather on it, keep some extra plugs in the car, watch the oil level, and try not to drive it too hard, and pray I don't lose all my compression. _________________
Posted: Wed Mar 28, 2007 5:36 pm Post subject: |
i'll bring my DVOM and Helms manual tomorow. we WILL get your revers lights and wipers working.  |
Posted: Wed Mar 28, 2007 5:46 pm Post subject: |
Cool Chris. It will be nice to see you piloting a thirdgen at a gathering. BTW, what is this 'try not to drive it too hard' crap? Like Hammer man says, drive it like you stole it!
Posted: Wed Mar 28, 2007 8:26 pm Post subject: |
HIs reverse lights don't work because he doesn't have the proper wiring for it. He needs to do what we did on yours and tap the green/blue and run wires/plug down there.
I need to pick up a wiper motor from the boneyard. Anyone know if the intermittant vs on/off motors are the same?
I also want one with the washer pump in the tank. |
Posted: Wed Mar 28, 2007 9:15 pm Post subject: |
| Twilightoptics wrote: | HIs reverse lights don't work because he doesn't have the proper wiring for it. He needs to do what we did on yours and tap the green/blue and run wires/plug down there.
paul's right. I have some sort of pinkish/black stripe wire, and black wire. I guess its some sort of diagnostic wire?? The plug fits, we'll just have to figure out how to spice it all together, to get them working.
wiper problem I think might be internal with the column......paul, AFAIK the motors are the same, the switch and the internal components on the column are what differs between 2 speed and intermittent. _________________
Posted: Wed Mar 28, 2007 9:18 pm Post subject: |
| Schultzy89GTA wrote: | Cool Chris. It will be nice to see you piloting a thirdgen at a gathering. BTW, what is this 'try not to drive it too hard' crap? Like Hammer man says, drive it like you stole it!
nah, I'll be nice to it for now. Its got some nasty blowby. I'd like to make it there and home piloting said third gen, and not have to have the assistance of a trailer and truck, if possible. _________________
Posted: Wed Mar 28, 2007 9:33 pm Post subject: |
Posted: Wed Mar 28, 2007 9:41 pm Post subject: |
| Get some BREATHERS and not a cap/pvc lol |
Posted: Wed Mar 28, 2007 9:50 pm Post subject: |
can I plug that line on the baseplate of the carb with the "T" joint to my PCV without any ill effects?
If so, I'll put a breather on each valve cover. _________________
Posted: Thu Apr 05, 2007 8:19 pm Post subject: Re: Quasi-Traction's personal checklist for Cows VI. |
| Quasi-Traction wrote: |
3) Bleed brakes
10) get reverse lights working
a big CHECK to numbers 4, 6, and 10.
from the sounds of chris's PM 8 is likley going to be completed soon.  |
Posted: Fri Apr 06, 2007 9:02 am Post subject: |
yeah, I just need to get a second muffler. You never told me if that Flowmaster you have was a Center/Center or a Center/Offset. If its offset on one side, I can clear my rear bumper.
Come on...sell it to me...DO IT!! _________________
Posted: Fri Apr 06, 2007 9:04 am Post subject: Re: Quasi-Traction's personal checklist for Cows VI. |
3) Bleed brakes
4) Replace passenger E-brake cable.
5) get new tags/registration
6) Install "temporary" exhaust (likely a couple short 3" pipes to glasspacks)
7) Get rear tires rebalanced, checked for leaks
Just seven more to go! MOOO!! _________________
