ore89iroc New Member
Posted: Wed May 05, 2004 7:40 am Post subject: Took out an aftermarket alarm, won't start |
Yes, a f$ck-up it was, but I thought it would be simple so I removed the alarm and the car won't crank. I can turn the key all the way but the starter doesn't even crank. It's probably VATS? Anyone proficient at wiring?
I'll post some pics this evening detailing where the alarm was patched into the steering column and in front of the fuse box.
 _________________ Ore89IROC
'89 IROC-Z, 350cid, 700R4, mostly stock |
Posted: Wed May 05, 2004 7:44 am Post subject: |
Chances are something didn't get hooked up right. the alarm probably had some sort of starter kill function. that is one possible issue. the other is VATS, if they set the alarm up to bypass vats somehow, then that is an issue, IRC even with an aftermarket alarm, vats still functions, since it is controlled in the computer, the computer is looking for the proper signal from the resister in the key.
when you turn the key to the 'On' Position, do you get gauge lights? |
Posted: Wed May 05, 2004 8:07 am Post subject: |
| Yes, gauge lights, radio, headlights, etc. at the 'ON' position. |
Posted: Wed May 05, 2004 10:19 am Post subject: |
| look under the dash where you took the alarm out. Look for a fat yellow or orange wire. That is the ignition to starter wire. The alarm should have taped that and split it. You need to hook that back up. |
Posted: Thu May 06, 2004 7:12 am Post subject: |
That's the problem, spliced 'em back and cranks up! WoooHaaa, i was going thru withdrawls after just one day.
Thanks TT! If your in the Eugene/Springfield area, I'll buy you a few rounds!
Now onto setting up manual control of my fans... |
Posted: Thu May 06, 2004 7:16 am Post subject: |
| ore89iroc wrote: | If your in the Eugene/Springfield area, I'll buy you a few rounds! |
Nope, The Young Jedi Master Paul, is not of the age to indultge in the frothy goodness known as beer. |
Posted: Thu May 06, 2004 7:41 am Post subject: |
| Dewey316 wrote: | | ore89iroc wrote: | If your in the Eugene/Springfield area, I'll buy you a few rounds! |
Yeah yeah, rub it in hoser~
Glad it was the easy fix!
BTW on your fans.... take the black wire on the relay.... tap into it.... (keep it factorty like) but run a wire from it into your passenger compartment... to a switch, then run the other side of the switch to any ground source.
That will control one of the fans. Not sure which wire you need to ground on the other relay. May also be black. |
kidcamaro Member
Joined: 09 Jan 2004 Posts: 325 Location: eugene/springfield
Posted: Thu May 06, 2004 7:19 pm Post subject: |
| im of age and i live near you so ill take them lol j/k. good to hear ya got the car goin again. |
Posted: Thu May 06, 2004 7:58 pm Post subject: |
ummm, Unca Schultzy is the designated drinker for the young lad. I prefer ales, um i mean Paully prefers ales
Glad you got her going man.
