T/A fuel pump in my RS
PostPosted: Thu Mar 15, 2007 9:45 pm    Post subject: T/A fuel pump in my RS Reply with quote
Ian hooked me up with the stock fuel pump from his T/A. My old pump must have been dying for quite a while 'cause the RS runs stronger than ever now. Perhaps the TPI fuel pump has a higher output than my MPFI pump? At any rate, at least one of my Camaros is mobile again! Thanks Ian! Very Happy
PostPosted: Thu Mar 15, 2007 9:58 pm    Post subject: Reply with quote
No problem man! Glad to get another thirdgen on the road.
I know they're different part numbers, don't know why though.
PostPosted: Thu Mar 15, 2007 10:02 pm    Post subject: Reply with quote
Hey, had to stop by your store for some 'fuel injection' hose and saw that you had the day off. I replaced the hard lines with the teflon insert hose so that it will be a much easier swap when I get the Walbro! Cool
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Sat Mar 17, 2007 12:30 pm    Post subject: Reply with quote
WTG John....
I thought you had started a new relationship for a sec... Did you put the pump in yourself?
I need mine replaced very soon
PostPosted: Sat Mar 17, 2007 3:06 pm    Post subject: Reply with quote
The TBI and TPI pumps are different part numbers also, but if you run out of umph with the TBI pump, tpi ones work fine.
I even put a TPI pump in my old vortec 4.3L when the TBI one went out.
PostPosted: Sat Mar 17, 2007 5:02 pm    Post subject: Reply with quote
85 T/A WS6 wrote:
WTG John....
Yeah, I replaced the pump myself. I did it using the "cut an access hole above the tank" method. I'll probably catch flak for that, but I had to do it in my driveway in the rain and it had to be done ASAP. I've used that method before and it worked out fine. I'm gonna make a lexan or fiberglass panel and attach it with hinges to make a real access door for the fuel sending unit. You probably won't want to go this route with your Recaro, Don! Wink
PostPosted: Sat Mar 17, 2007 5:17 pm    Post subject: Reply with quote
That's not a fun job anyway you look at it. It's funny how cold and rain will make us do anything to get the job done! Wink Keep in mind that the metal floor is a fire barrier between you and the gas tank. You might want to weld a plate back in now that it's all done.
PostPosted: Sat Mar 17, 2007 6:02 pm    Post subject: Reply with quote
Perhaps I'll make my access door out of metal and find some way of making it airtight...
PostPosted: Sat Mar 17, 2007 6:10 pm    Post subject: Reply with quote
In which case you need to pull the tank and plug the lines and make sure you don't catch the left over fuel on fire or the carpet...
Hell... should have just pulled the tank in the first place Rolling Eyes Wink Very Happy
PostPosted: Sun Mar 18, 2007 1:06 am    Post subject: Reply with quote
the "cut a hole in the floor" is seen as "hack job" by most. i agree to a point. if you allready have the tank out i see no issue with cutting an access door for future pump swaps. MANY production cars have fuel pump access doors from the factory, including the Nissan 240SX and BMW E30s (only other cars i have experiance with fule pumps on). in fact, summit sells pre-made doors you can weld, screw, bolt or otherwise put in place. it is a common modification on cars without them i guess.
as far as doing it with the tank in the car... i have cut on a camaro in the past (remember chris's 84 v6?) and know there is about 4" from the floor to the tank. plenty of room. but there is no way i would do it to my car.
PostPosted: Sun Mar 18, 2007 8:04 am    Post subject: Reply with quote
I did it using the "cut an access hole above the tank" method. I'll probably catch flak for that....
You're wearing your flak jacket, right? Very Happy
PostPosted: Sun Mar 18, 2007 8:07 am    Post subject: Reply with quote
just do it right like normal people. it was easy. unless you like to inhale gases and produce future meth heads of america. it don't take long.
Sellmanb
PostPosted: Sun Mar 18, 2007 9:11 am    Post subject: Reply with quote
while it isnt the preferred method, a proper seal around the access hole will prevent fumes from entering the passenger compartment. There are many production vehicles (none GM that I've seen though) that have access holes from the factory, and you'd never know it.
PostPosted: Sun Mar 18, 2007 9:54 am    Post subject: Reply with quote
Wow, its almost like I saw this coming! Laughing I've seen this debate rage on TGO enough times to realize that some (not most) people view this as a "hack job". There are others who say an access hole is the way to go. I feel that the addition of an access hole (once I get it sealed up properly) for future pump replacement is a worthwhile modification. Wink
PostPosted: Sun Mar 18, 2007 9:56 am    Post subject: Reply with quote
BigDaddyVu wrote:
just do it right like normal people...
Hey, thanks for suggesting that I'm not a normal person, I'll take that as a compliment! Very Happy
PostPosted: Sun Mar 18, 2007 4:45 pm    Post subject: Reply with quote
have you met normal people? that IS a compliment.
PostPosted: Sun Mar 18, 2007 6:11 pm    Post subject: Reply with quote
Certainly can't be 'normal' if you want to be part of this crew. Very Happy
PostPosted: Sun Mar 18, 2007 9:51 pm    Post subject: Reply with quote
The people that consider it a hack job are usually the ones that spent several hours removing their fuel tank.
Some previous owner of my car did a stand out job of putting in an access panel for the fuel tank. I believe that a chainsaw was his tool of choice. It looks like absolute shizzle. I took some thick plastic sheets and sealed it of with duct tape and it is fine for the time being. can't see it at least and no fumes are getting in. I'll fix it right someday. A nicely done access door would be a simple project. I know that if I ever have to change the fuel pump on Jen's Firebird it will have a well made access panel.
PostPosted: Sun Mar 18, 2007 11:13 pm    Post subject: Reply with quote
Rod, didn't I give you a bunch of factory sheetmetal Tony and I cut off from my 84 for the repair on that part?
you also have a PM.
PostPosted: Mon Mar 19, 2007 6:55 pm    Post subject: Reply with quote
rjmcgee wrote:
I took some thick plastic sheets and sealed it of with duct tape...
Call it a performance mod for weight reduction and the next thing you know it will be the next 'in' thing to do. Very Happy
