Replacing Fender
J-Dog-III
PostPosted: Mon Dec 11, 2006 10:16 pm    Post subject: Replacing Fender Reply with quote
I currently am driving around with a crumpled passanger side fender and it's getting really annoying...So i bought a used fender for 20 bucks and painted it somewhat the color of my car Razz. I've read a little on TGO and got the just of how to get the fender off..but im kinda stuck...
I know i have to undo the bolts ontop of the fender/ under hood
But do i have to take off the GFX and take off my RS badge to ge to a bolt to finish off the job? if anyone has pictures or anything it might help me...
PostPosted: Tue Dec 12, 2006 6:11 pm    Post subject: Reply with quote
RSFreak and I did this a few months back, and the answer is yes to your 2 questions. Plus, there is another screw under the car (close to the badge) that is a pain to remove as alot of times it's mashed in. Good luck!
TJ
PostPosted: Wed Dec 13, 2006 12:06 am    Post subject: Reply with quote
There are also 4 bolts which hold the front fascia to the fender. Those are a real PITA to get to! And yeah, like TJ said, there are two screws under the badges (be careful, I broke mine removing it) and a bolt on the underside behind the gfx. We didn't remove the entire gfx, just enough of the retaining screws (top and bottom) to pull it out of the way.
