Blower motor for a Non AC box.
PostPosted: Wed Nov 01, 2006 7:47 pm    Post subject: Blower motor for a Non AC box. Reply with quote
as the post reads.....mine's toast in my Berlinetta.
I haven't had a chance to check the Stealership...if anybody out there's got one, lemmie know.
PostPosted: Wed Nov 01, 2006 7:48 pm    Post subject: Reply with quote
Might steal an A/C blower and swap the fins. Have to cut the armature down a but and thread it.
PostPosted: Wed Nov 01, 2006 7:52 pm    Post subject: Reply with quote
I know...I'm kind of trying to avoid that method...but if it comes to it, I'll cave and do it.
PostPosted: Wed Nov 01, 2006 8:43 pm    Post subject: Reply with quote
They come up all the time on TGO. Only problem is most people want a fair bit of change for them.
PostPosted: Wed Nov 01, 2006 9:02 pm    Post subject: Reply with quote
They're $19.99 at napa. Part # 455-1039.
PostPosted: Wed Nov 01, 2006 9:13 pm    Post subject: Reply with quote
Surprised Does that include the cage too, or just the motor?
PostPosted: Wed Nov 01, 2006 9:15 pm    Post subject: Reply with quote
Motor only.
PostPosted: Wed Nov 01, 2006 9:18 pm    Post subject: Reply with quote
The cage is $21.99 by itself. part # 655-1406
PostPosted: Wed Nov 01, 2006 11:44 pm    Post subject: Reply with quote
Thanks brandon!
That's cheap enough its worth it to buy it new.
I'll be sure to hit napa this week.
PostPosted: Mon Nov 06, 2006 11:48 pm    Post subject: Reply with quote
Brandon,
Got on NAPA's website and checked out a new blower motor. I found two for a Non/AC car..a premium for $43.99 and a value for $19.99.
Is there any difference between the premium and the Value series in terms of warrenty and of how well the motor works?
PostPosted: Tue Nov 07, 2006 7:53 pm    Post subject: Reply with quote
No idea. Alot of napa stuff has a shorter warranty the more you pay for it. Which is really strange. I think we only stock/sell hte cheap line at our store. My last one was a Semens brand.
PostPosted: Wed Nov 08, 2006 11:18 am    Post subject: Reply with quote
I guess I'll give the $19.99 one a try then.
I think I need to do some investigation on my wiring for the wipers......... it froze again #$%^&*
PostPosted: Thu Nov 09, 2006 6:32 pm    Post subject: Reply with quote
Came back to town this afternoon with a new blower motor and changed them out in the berlinetta....still not the problem.
Started checking wiring and my grounds...all seem to be rock solid. Figured I might as well try the resistor
Took the NewBlower motor back one back and bought a new resistor....TA-DA!! FIXED!!! Rock on!
now I just have to reconnect my engine bay hoses, and i'll have heat!
PostPosted: Thu Nov 09, 2006 7:36 pm    Post subject: Reply with quote
Get those 3/8" head header bolts yet?
PostPosted: Thu Nov 09, 2006 10:46 pm    Post subject: Reply with quote
not yet, thinking about switching the location of two of the bolts. It was the allen bit that was sripped on the bolt right? why not just put one in that doesnt have a stripped allen head? Any reason why we didn't do that spesifically?
Doing that and remounting the torque arm tomorrow. Eventually I'd like to relocate the TA to the crossmember, but I haven't quite figured out a way to engineer/fabricate that yet.
Thinking about ordering two Dynomax 4" round (2 1/2" pipe Dia) 'bullet' mufflers and mounting them almost parallel with the rear frame rails. Mo-Fo will be loud without a doubt, but that's ok.
Found a way to route it that I like. Looks like I"ll be able to tuck it up pretty tight to the body too!
check this out
more details will be in another thread, the closer it gets to me making this happen.
PostPosted: Fri Nov 10, 2006 12:03 am    Post subject: Reply with quote
we did not do that originaly because the allen heads on those header bolts strip out to easy. they are a bunch of BS. if you want allen headed header bolts you need dedicated alen headed bolts, none of this hex/allen Bollux. Rolling Eyes
i advise buying a whole new set of header bolts.
