interior
paranoid
PostPosted: Tue Oct 31, 2006 12:25 am    Post subject: interior Reply with quote
is the interior between the 89 firebird and a 92 firebird the same.
PostPosted: Tue Oct 31, 2006 1:59 am    Post subject: Reply with quote
For the most part, yes. There are quite a few things that changed though. Dash bezel, switch panel, knee kick panel below steering column, plastic trim around door handles. What did you want to swap?
paranoid
PostPosted: Wed Nov 01, 2006 2:48 am    Post subject: Reply with quote
well i wanted to swap my interior for black and i found a guy selling a full black interior out of a 92
PostPosted: Wed Nov 01, 2006 4:15 am    Post subject: Reply with quote
other then doorpannals all the stuff you will want to swithc should be the same. the rest of that stuff (dash, kickpannals) are the same color on all models. well, on birds anyway....
PostPosted: Wed Nov 01, 2006 10:09 am    Post subject: Reply with quote
Some birds come with grey dash plastics (think passanger side where the glove box would go) and some got the black stuff. Shrug
PostPosted: Wed Nov 01, 2006 12:17 pm    Post subject: Reply with quote
hmmm... news to me, thanks ian. Smile
paranoid
PostPosted: Wed Nov 01, 2006 3:59 pm    Post subject: Reply with quote
yeah cause my interior is kinda trashed right now, the dash pad is cracked and where its supposted to be connected in the front corners its not. and while i have that apart i could try adn fix my heading which only come out the top vents not the ones in the front of the dash. i have worn the carpet through so its just the mesh stuff with no material in it the headliner is starting to fall apart and some of the plastics have had the screws pulled threw them so they rattle like hell.
PostPosted: Wed Nov 01, 2006 6:03 pm    Post subject: Reply with quote
To change your HEADING turn your steering wheel.
If you meant to type HEATER, but was in too big of a hurry to actually read what you typed, make sure the vacume line under the hood is hooked up. Without vacume our cars default to the defrost setting. The vacume line will be around the heater box under the hood.
PostPosted: Wed Nov 01, 2006 6:15 pm    Post subject: Reply with quote
If the underhood line is connected, pull the heater controls out of the dash. The line can come undone at that end as well, although the under-hood problem is more common.
PostPosted: Wed Nov 01, 2006 7:57 pm    Post subject: Reply with quote
that or they just melt/break in the middle of the line right where it enters the engine bay. i had this problem with mine.
PostPosted: Wed Nov 01, 2006 8:42 pm    Post subject: Reply with quote
Mine was actually not even the line itself, but the control unit was leaking. Never heard of anyone else with that problem. Rolling Eyes
paranoid
PostPosted: Thu Nov 02, 2006 8:46 pm    Post subject: Reply with quote
sorry was kinda tired when i wrote that. but yes, i ment my heater and ill check it out next time our shop is free (to many blocks and spare parts sitting around to get the car in
PostPosted: Thu Nov 02, 2006 9:04 pm    Post subject: Reply with quote
Takes about a minute to fix, man. Just open the hood and look for the small T in the vacuum line coming back from the intake on the passenger side (assuming you have TPI).
paranoid
PostPosted: Sat Nov 04, 2006 11:24 pm    Post subject: Reply with quote
v6 mpfi
PostPosted: Sun Nov 05, 2006 6:47 am    Post subject: Reply with quote
Shouldn't be too different, right Tony? If in doubt, look for the vacuum line/emissions diagram under the hood, and find the line marked HVAC.
PostPosted: Sun Nov 05, 2006 10:46 am    Post subject: Reply with quote
PostPosted: Sun Nov 05, 2006 11:50 am    Post subject: Reply with quote
Another professional diagram. Cool
PostPosted: Sun Nov 05, 2006 1:09 pm    Post subject: Reply with quote
I like the technical names, like "The Orb of Power". Very Happy
PostPosted: Sun Nov 05, 2006 9:16 pm    Post subject: Reply with quote
Hmm... I like the distributor magically floating next to the block. Wink
