Posted: Tue Oct 03, 2006 10:26 am Post subject: A note to power steering |
1. It's Overrated.
2. Make sure your fittings are tight.
3. Don't run it dry for even 5 miles.
If you do not follow the above advice... that loose fitting will cost you $65
Posted: Tue Oct 03, 2006 10:31 am Post subject: |
What did you toast, the pump or the box?
I saw in the summit mag, that there is a manual conversion kit for our cars.  |
Posted: Tue Oct 03, 2006 10:40 am Post subject: |
The pump. You can drive on the box just fine it's just not ratioed right. I don't know about long term effects on the box, but you remember when I used to chuck PS belts?
Yeah fried the pump spinning empty. I was even careful not to get the revs up past 2k on the way home. |
Posted: Tue Oct 03, 2006 10:44 am Post subject: |
| That sucks. I need to figure out what is going on with my steering, it is getting worse and worse. I may need to put a new box in mine. |
Posted: Tue Oct 03, 2006 11:23 am Post subject: |
I guess that means she is back in action though eh?
-Schultzy |
Posted: Tue Oct 03, 2006 11:52 am Post subject: |
| Not yet. Need to go pick up a pump and pulley puller. |
Posted: Tue Oct 03, 2006 11:55 am Post subject: |
| I have my old serp pump in the garage, if you want that? |
Posted: Tue Oct 03, 2006 2:30 pm Post subject: |
| i have a pulley puller you could borrow. |
Posted: Tue Oct 03, 2006 10:37 pm Post subject: |
| Xophertony wrote: | | i have a pulley puller you could borrow. |
Power steering ones seem to be a bit specific. Thanks though. Just going to go buy one. Got a new ... well reman pump today. |
Posted: Wed Oct 04, 2006 2:43 am Post subject: |
| it is a power steering pulley puller. i think vato-zone rents em too. |
Posted: Wed Oct 04, 2006 9:45 am Post subject: |
| All of it doesn't help if your new pump is rotated in the housing and wont fit your bracket. :rolleyes: |
Posted: Wed Oct 04, 2006 1:06 pm Post subject: |
Is anyone driving an fbod with the pump unconnected??? Whenever I push the car around without the engine its a pain to turn the wheel. I couldn't imagine driving it without it! Being that I'm in the weight saving mood, it would be nice to shed it..... Are there any other boxes that are smaller that would work just as well? Ive heard of using the S10 manual box, but I won't sacrifice the 2.5 turn L-L. _________________ E30
Posted: Wed Oct 04, 2006 2:57 pm Post subject: |
There are a few sites on ebay that sell them....
Someone told me once you just have do punch one extra hole and you can use a 2nd gen manual box.
I have frequently considered doing this mod....I think you have to change the pittman too... _________________
Posted: Wed Oct 04, 2006 3:19 pm Post subject: |
If you run a manual box, you're going to get the larger ratio which means more than 2.5 turns Lock to Lock.
Just run the PS unit. It's not that big of a deal. Personally I like being able to powerslide using my left pinky, shifting with the right hand, and holding a soda with the left. |
Posted: Wed Oct 04, 2006 3:23 pm Post subject: |
| Hehe, I know. I've oftened wondered about turning mine down a tad, just so I can get some more wheel feel back. Pinto racks would be nice, but they are against a lot of rules if you race. |
izcain 9sec Club
Posted: Wed Oct 04, 2006 9:56 pm Post subject: |
I was @ the track this year and had a belt failure right at launch.... Made for some hairy times when the car jumps sideways and you dont have power steering but your still thinking you do lol! Oh well got er steered out and even managed to stay on it. I have thought about the manual steering as well but then my short cruise to work would be much more hassle  _________________
9.17 @ 148 |
Posted: Wed Oct 04, 2006 10:09 pm Post subject: |
| you could always pull the belt off at the track. |
Posted: Wed Oct 04, 2006 10:56 pm Post subject: |
| Xophertony wrote: | | you could always pull the belt off at the track. |
and have similar results that paul had.
I have a PS unit on my Berlinetta, and until it has some major failure I have no intention of changing it to a manual. _________________
