Slicks?
PostPosted: Mon Sep 04, 2006 6:14 pm    Post subject: Slicks? Reply with quote
What are my options? I want 28" tall and I want to put them on a couple 15x7 Z28 wheels.
PostPosted: Mon Sep 04, 2006 6:40 pm    Post subject: Reply with quote
Do you want full on bias ply slicks or drag radials?
If you're looking for the radials....Mickey Thompson has the ET Radial 3752R...I'm about 95% certain they'll fit the 15" Z/28 star wheels.
Here's the link:http://www.mickeythompsontires.com/strip.php?item=ETStreetRadial
if you got an Americas Tire Company, you can prolly get em there, they can get you just about anything you want. Might cost you a little more $$.
Drag slicks, track slicks, autocross? Street legal or dedicated for track?
PostPosted: Mon Sep 04, 2006 6:54 pm    Post subject: Reply with quote
hmm 15x7 you'll push the width limit. Thats why I went with te 16x8. No traction problems with the 28" as you all know. Some people are saying that drag radials are becoming more sticky.
Radials are better also I was being explained by racers, due to the fact that you run a higher pressure, so drag on the tires is lighter at high speeds.
I'm running the MTT-3793R ET STREET RADIAL 255/50-16
When you get into full slicks it another research battle. If you get slicks that require too low an air pressure, you have to run tubes and rivet the tires to the rim so they don't spin. Alot of full slicks are tubed.
PostPosted: Mon Sep 04, 2006 7:33 pm    Post subject: Reply with quote
Paul, are those 26 or 28 inches tall. I have considered those since I have some 16" wheels.
I was thinking of something that will wrinkle since it should be easier on the drivetrain and I have some 15x7 wheels. I don't mind changing them at the track since I'm lucky to get there once every two years.
82camaro383
PostPosted: Mon Sep 04, 2006 8:10 pm    Post subject: Reply with quote
On my z28, I am using the MT 26/10/15C slicks. They are a softer compound than the normal slicks. They hook up good. I'm happy with them.
Nathan J
1986 Pontiac Firebird
PostPosted: Mon Sep 04, 2006 8:26 pm    Post subject: Reply with quote
just because they wrinkle does not mean it will be easyer on the drivetrain, you will be more likely to break the weak factory stuff on true slicks then dr, also if you let the tires sit alot like only racing on them once or twice a year after. they start to get hard and they will not hook aswell. just some think about before you spend the cash if its really worth it.
Nathan
86 firebird
383sbc
th350 t brake
4th gen rear soon 9in ford rear
PostPosted: Tue Sep 05, 2006 5:35 pm    Post subject: Reply with quote
15x7? Check out the import forums and you'll probably find out. Razz
PostPosted: Tue Sep 05, 2006 6:36 pm    Post subject: Reply with quote
Do you have slicks for your Firebird? Cause I could buy it for the slicks. Razz
PostPosted: Tue Sep 05, 2006 6:43 pm    Post subject: Reply with quote
10 thousand dollar slicks? Sounds like a good investment to me. Very Happy
PostPosted: Sat Sep 09, 2006 9:16 am    Post subject: Reply with quote
If you don't know by now then it's clear to me that I must make more posts on the subject.
And who said I would go as low as $10K? Wink
PostPosted: Sat Sep 09, 2006 8:50 pm    Post subject: Reply with quote
I got a pair of 28 inch tall wrinkle wall slicks coming this week. Cool
PostPosted: Sun Sep 10, 2006 8:44 am    Post subject: Reply with quote
Thumbs up
PostPosted: Sun Sep 10, 2006 10:18 am    Post subject: Reply with quote
I'll bring the camera and a socket to take the diff cover off and see all the carniage!
PostPosted: Sun Sep 10, 2006 1:50 pm    Post subject: Reply with quote
... and then you'll be sorry you didn't buy my Firebird since it has a strong rear axle. Very Happy
PostPosted: Sun Sep 10, 2006 6:09 pm    Post subject: Reply with quote
Probably, but it will be a nice feeling to know that my little 350 is faster than your blown big block. Pokey pokey
PostPosted: Sun Sep 10, 2006 6:40 pm    Post subject: Reply with quote
Just try to keep it all in one piece now. Hope you have fun with the new axle/tire setup and let us know how it works out. Cool
PostPosted: Sun Sep 10, 2006 7:41 pm    Post subject: Reply with quote
Thanks, I'm actually more worried about the transmission then the rear at this point. I think she'll hold together though, just gotta have faith. Laughing
PostPosted: Sun Sep 10, 2006 8:18 pm    Post subject: Reply with quote
What did you do to make the posi work Rod? buy another??
PostPosted: Sun Sep 10, 2006 8:41 pm    Post subject: Reply with quote
Nope, just drove around a little and it seemed to get better. Maybe had to get the additive in the oil inside it or something. I did a full on 1st and 2nd gear burn out tonight and it spun both the whole time. Seems weak if I romp on it in a right hand corner as it just spins one. Got to get the Eaton pretty soon but I think this one will do fine next weekend.
