While you guys were playing in Canada....
Goto page Previous  1, 2, 3
CheezX
PostPosted: Fri Sep 01, 2006 11:17 am    Post subject: Reply with quote
Oil pressure switch is supposed to shut the fueling OFF when there is no oil pressure in the event of an accident.
IIRC under wiring diagrams, when the key is at "start" it runs through a different piece of the circuit that allows fuel when the oil pressure isn't there.
Actually it's just a backup circuit to get power to the pump in case the relay fails. If oil pressure hits zero the engine still runs as the relay will keep the pump operating. Maybe it's different on pre-90 cars, but that's how 90-92 is.
CheezX
PostPosted: Fri Sep 01, 2006 11:21 am    Post subject: Reply with quote
The Dan's...
All signs are pointing to the pulsator. Looks like the tank is coming back out this weekend, and I will be replacing the pulsator. I will probably just go with high-pressure rubber fuel line, and real hose clamps.
I sure hope that fixes it. I really don't want to be taking the fuel tank out of the car for a third time!!!
--john
Definitely keep a pulsator in the system, this will help with a smoother idle and better gas milage. If you look at the tuning side of it, less BLM, INT variation. The pulses will make more difference when injector pulse width is short.
PostPosted: Fri Sep 01, 2006 11:35 am    Post subject: Reply with quote
We know schultzy's car ran without oil presssure.
CheezX
PostPosted: Fri Sep 01, 2006 11:53 am    Post subject: Reply with quote
Mine does too. Embarassed
PostPosted: Fri Sep 01, 2006 11:57 am    Post subject: Reply with quote
I know mine will to, every now and again, if I really toss my car hard into a right hander, my pressure will drop to zero. Car still runs.
I really need to get one of them wicked cool Canton road-race oil pans.
PostPosted: Fri Sep 01, 2006 8:55 pm    Post subject: Reply with quote
...Not so much. My stock sensor isn't even connected to the vehicle at this point. The connector is ziptied back away from the block.
As for the start thing, mine starts without the key having to go all the way to "start."
Is the pulsator the section of tubing between the pump and the top of the tank?
PostPosted: Fri Sep 01, 2006 9:02 pm    Post subject: Reply with quote
My car wouldn't maintain the fuel if it was unplugged.
Maybe a maf thing?
PostPosted: Fri Sep 01, 2006 9:55 pm    Post subject: Reply with quote
Maybe a maf thing?
Shrug
Could very well be.
Page 3 of 3
