Midnight Sun Member
Posted: Mon Mar 15, 2004 6:43 pm Post subject: Door Handles |
I think I have a pretty good idea on how to take them off. But could someone briefly describe removing the exterior doorhandles before I try it myself and end up breaking something.
Thanks
-Eric _________________
PonchoTA Member
Posted: Mon Mar 15, 2004 7:34 pm Post subject: |
I don't remember all the details, but it does involve taking off the inner door panel. (duh!)
It also involves taking off the operating rod, and there are 2 bolts that hold the handle to the door.
Make sure to either replace or at least clean the gasket. A little silicone on the rubber wouldn't hurt either.
Personally, I would spray rust preventative all over inside the door while I had the panel off too!
hth,
Paully |
Midnight Sun Member
Posted: Mon Mar 15, 2004 10:51 pm Post subject: |
| PonchoTA wrote: |
hth,
Paully |
The whole door is getting repainted  _________________
Posted: Tue Mar 16, 2004 8:06 pm Post subject: |
| If you're painting the door dont go anywhere near it with silicone until afterwards. Silicone is the hardest thing to get off and absolutely no paint will stick to it. |
Midnight Sun Member
Posted: Tue Mar 16, 2004 11:28 pm Post subject: |
| chevymad wrote: | | If you're painting the door dont go anywhere near it with silicone until afterwards. Silicone is the hardest thing to get off and absolutely no paint will stick to it. |
Noted.
Between you and Paully... I should just give you guys the car when I am done. Thanks a lot. _________________
