Header gaskets
PostPosted: Mon Aug 28, 2006 8:19 pm    Post subject: Header gaskets Reply with quote
Well..........as they say, a picture is worth a thousand words. Found out Mr. Gasket "Ultra Seal" gaskets aren't very "ultra". Next to it is one of the new Percy's gaskets I used. Only did the left side..........that was enough for one day. Will do the right side when it starts leaking.
PostPosted: Mon Aug 28, 2006 8:27 pm    Post subject: Reply with quote
Ultra-Seal = Ultra-Crap. That looks about like the one I pulled out of my car.
Ironic thing is that one of the previous owners had replaced one of the sides with a regular Mr. Gasket and it was a little burnt in one cylinder, but not in bad shape, considering.
PostPosted: Mon Aug 28, 2006 9:31 pm    Post subject: Reply with quote
Yup yup
Yup, I did those gaskets and the locking bolts when I installed the headers 2 or 3 years ago. Never have had to touch them since. No leaks.
PostPosted: Tue Aug 29, 2006 7:36 am    Post subject: Reply with quote
Nitro seal all the way Rock on!
PostPosted: Tue Aug 29, 2006 9:29 am    Post subject: Reply with quote
are you running round tube headers on a square tube head? Just noticed that the gaskets are different.
PostPosted: Tue Aug 29, 2006 9:30 am    Post subject: Reply with quote
I would have thought ultraseal would have been close to the nitro seals. But the nitro's definately don't do that. I've lost a bolt before and left the header leaking for a month.. no visible sign of damage to the nitro seal. I just put a bolt back in and tightened her up, probably still using the same gasket.
PostPosted: Tue Aug 29, 2006 9:32 am    Post subject: Reply with quote
Good eye. Looks like a port mismatch on that first gasket. If your header has the raised round sealing ring you want the round port header gasket. If its got a square sealing ring you want the square gasket. Otherwise it gets too thin in the corners.
PostPosted: Tue Aug 29, 2006 10:28 am    Post subject: Reply with quote
Looks like the new gaskets will be correct. The old ones were wrong.
PostPosted: Tue Aug 29, 2006 10:38 pm    Post subject: Reply with quote
The square ports ones were recomended as an upgrade for the square ones supplied with the headers. And if you look, it's not just the corners that blew out. They lost it everywhere........not just the corners. I decided to try the round ones for the hell of it.
