turbo_jimi Member
Posted: Wed Aug 09, 2006 7:40 pm Post subject: Edelbrock Intake and Carb |
Looking to install an Edelbrock Intake Manifold :Performer/non-egr (part 2101) and an Edelbrock Performer 600 Carb (part 1406). Wondering what kind of Fuel Pump and Filter should I go with on this set-up and looking for any advice for anything else that will optimize this part of the upgrade. Thanks!
TJ _________________
Posted: Wed Aug 09, 2006 8:45 pm Post subject: |
| What do you have on it now? An on-block or in-tank? |
Posted: Wed Aug 09, 2006 8:54 pm Post subject: |
im running the edlebrock performer intake and a holly carb and i had to switch from an electric fuel pump to an on block mechanical. works great now also i don't have to worry about fuel pump wires anymore.
turbo_jimi Member
Posted: Wed Aug 09, 2006 9:26 pm Post subject: |
Fuel pump is on-block...btw, if i were to go with the carb, should i go manual or electric choke? _________________
Posted: Thu Aug 10, 2006 3:35 pm Post subject: |
I have an electric choke and it works well once you have it adjusted right. manual is just a pain
~JAKE |
Posted: Thu Aug 10, 2006 9:33 pm Post subject: |
| 83Z28BlackBetty wrote: | I have an electric choke and it works well once you have it adjusted right. manual is just a pain
~JAKE |
Electric choke I think would be better for an F-body. I wouldn't want to have to route an extra cable through the firewall and find a place on or under the dash to mount a manual choke cable. Electric is just a matter of finding a hot wire, doing some splicing for a 12v source.
...or were you talking about going with mechanical vs Vaccum secondaries on a carb? _________________
BigDaddyVu 12sec Club
Posted: Fri Aug 11, 2006 5:22 pm Post subject: |
i've used the stock pump for 6 years with my my edlebrock intake and carb. until i installed a holley mech. pump it runs at 7.5 psi@80 gph. the holley electric pump and regulator is a lil steep in price. but i needed something to feed my holley. i decided to swap out carbs after being sick of the elderbrocks keep flooding and killing my my car when taking sharp turns. holleys don't do that. _________________
turbo_jimi Member
Posted: Mon Aug 28, 2006 1:08 am Post subject: |
Got the intake on...leaving the q-jet on for a while longer...next, chrome valve covers  _________________
