wanarunhard Member
Posted: Tue Jul 18, 2006 8:49 pm Post subject: o k last chance 89 pontiac firebird parting out |
| 89 pontiac firebird tilt colum center console shift etc im keeping eng 2.8 selling trans 700r4 |
Posted: Tue Jul 18, 2006 9:01 pm Post subject: |
Do you have a cruise control signal stalk with windshield washer control?
edit: correct that. I need the switch that the stalk plugs into
-Schultzy |
Posted: Tue Jul 18, 2006 9:47 pm Post subject: |
| turn signals going out? i got two steering colums for sale if you want to do it that way (easier then tearing into a column in my opinion) |
wanarunhard Member
Posted: Wed Jul 19, 2006 7:07 pm Post subject: ok |
im taking car to jyard in morning it has tilt colum works good no cruise with delay right door and panel with mirror opens nice no dropping right tailight is cherryalso nose and hood no cracks thats it i suppose
[/b] |
Posted: Wed Jul 19, 2006 7:24 pm Post subject: |
i'm thinking that my windshield washer switch is out - everything else works great just no squirtage. Brandon said that the stalk plugs into the switch.
-Schultzy |
Posted: Wed Jul 19, 2006 7:29 pm Post subject: |
| Are you sure it's not the fluid pump? |
Posted: Wed Jul 19, 2006 7:38 pm Post subject: |
not positive - i'll test it. shouldn't be too hard it is the external type.
-Schultzy |
Posted: Wed Jul 19, 2006 7:40 pm Post subject: |
| I had to replace the washer pump once. It might be worth checking. |
Posted: Wed Jul 19, 2006 7:46 pm Post subject: |
| I had the internal type, and it still only took a second to test it. I don't know how much the in-tank ones are, but mine was like 21 bucks. |
Posted: Wed Jul 19, 2006 7:48 pm Post subject: |
Nope. Pump is fine.
-Schultzy |
Posted: Wed Jul 19, 2006 7:55 pm Post subject: |
| Getting power to the wires? It still isn't automatically the switch, the tubes and nozzles do get f***ed up. |
Posted: Wed Jul 19, 2006 7:56 pm Post subject: |
Bummer. Looks like you're in for a fun weekend... of repair work. The older I get the more I hate those kind of weekends and the easier my wallet opens to just have it done. |
Posted: Wed Jul 19, 2006 8:22 pm Post subject: |
[quote="Asdfga3"]Getting power to the wires? It still isn't automatically the switch, the tubes and nozzles do get f***ed up.[/quote
got it dude. it recently went out. hadn't done the diagnostics. if there is a free switch available thought i would post up. Thanks for the help.
tubes and nozzles are fine - i just hot wired the pump and it worked great. 'could' be something between the switch and pump in the wires but not likely.
-Schultzy |
Posted: Wed Jul 19, 2006 8:26 pm Post subject: |
| Nope. Usually it'll either be a bad pump motor, or a clogged pipe. I had both on mine. Threw me for a loop at first. |
Posted: Wed Jul 19, 2006 8:28 pm Post subject: |
not quite following you bubba.
i just ran the fricking pump and it squirted out just fine.
what are you not getting.
-Schultzy |
Posted: Wed Jul 19, 2006 8:31 pm Post subject: |
I was actually agreeing with your comment about the wiring. My point was that if it's not the piping up to the wipers, or the pump, then the switch is about the only other thing it can be. |
Posted: Wed Jul 19, 2006 8:32 pm Post subject: |
AHHH. gotcha hehe.
thought we were stuck in a continuous loop there
-Schultzy |
Posted: Wed Jul 19, 2006 8:34 pm Post subject: |
We actually might be.... you never know.  |
Posted: Wed Jul 19, 2006 8:35 pm Post subject: |
| Asdfga3, I think that's your que to let it be. I trust that Schultzy has a good handle on it. If he needs advice then he'll post in the Garage section. |
Posted: Wed Jul 19, 2006 8:38 pm Post subject: |
*salutes*
Yeah, we hijacked this thread way to long. |
