what I did
PostPosted: Mon Jul 17, 2006 10:30 pm    Post subject: what I did Reply with quote
well i had installed my orignal axel rebuilt with 3.73 and eaton posi, bought new tires cooper cobras with the raised white lettering facing out (going for the era correct look), also installed a new holley 670cfn avenger. Its kinda squirlly around turns the posi really makes the tires bark. the holley seems to have a consistant and smooth power. may need a spare tranny t-5 world class if i could find one.
PostPosted: Mon Jul 17, 2006 10:31 pm    Post subject: Reply with quote
Sounds like some nice upgrades. Was it an open diff before or did you just blow it up? Which car?
PostPosted: Tue Jul 18, 2006 5:33 pm    Post subject: Reply with quote
I blow up the orginal 3rd member and been using a 3.53? posi disc. i decided to have the orginal axel to be rebuilt with motive gear ring and pinion and eaton posi.
PostPosted: Tue Jul 18, 2006 5:34 pm    Post subject: Reply with quote
BTW i am using the "royal purple" systhetic 75w90 lube with limited slip additive
PostPosted: Tue Jul 18, 2006 8:31 pm    Post subject: Reply with quote
I just bought some of that because it was a dollar cheaper than mobil 1. You like?
I got my two quarts for $13 Smile
PostPosted: Thu Jul 20, 2006 5:44 pm    Post subject: Reply with quote
i like it. alot of racers uses that oil and haven't heard of anyone having problems with it. and it was sudjested by the shop that rebuild my axel.
PostPosted: Thu Jul 20, 2006 9:14 pm    Post subject: Reply with quote
i installed a new holley mech. pump(80gph @ 7.5psi) today to help feed the power demands of my right foot.
