i broke my car at the track... sort of...
PostPosted: Sun Jul 16, 2006 2:23 pm    Post subject: i broke my car at the track... sort of... Reply with quote
so, after my 2nd run with the vee-six chris and i noticed a valve rattle sounding noise. well, now that i drive the car when there are not 200 cars reving their engines in the area i can hear it... it is BAD! comes in whenever i am above 1/4 throttle. we figured out that it was the rear most cylindar in the passanger side (same place i have an exhaust manifold leak). anyway, so now i need to pull my valve covers and re-set my valve lash.
....who knows why that is a PITA on a MPFI 60* engine...? anyone? anyone? ..... because you need to remove the entire upper and lower intake manifolds to get to them Rolling Eyes thanks GM. anyway... i will probably be tackling that tomorow, i have never actualy done thison an american car before, did it on my sazuki samurai once. if anyopne has any usefull tips or tricks i would love to hear them. thanks.
PostPosted: Sun Jul 16, 2006 3:48 pm    Post subject: Reply with quote
..... my car just healed itself? ... the noise is now gone. no matter how high i rev the engine, or how much load i put on it (4th up a hill at 20MPH) i can not replicate the issue. i'll try it again late tonight and see if i can replicate it with a cold engine.
PostPosted: Sun Jul 16, 2006 4:06 pm    Post subject: Reply with quote
The way I did it on the LG4 when I put budgetracers old heads on it was to rotate the motor over to the intake stroke with #1 at TDC. I didn't remove the lifters out of the block so everything was in place there. I'm not sure what the proper procedure is if you have to remove the lifters and replace them.
with hydraulics I didn't spesifically set lash. All I did was tighten each rocker arm nut down until the pushrod seated on one side and the tip that hits the valve made enough contact where I couldn't get a .020 feeler gauge in there. After that I turned an extra 1/2 turn on each one.
DISCLAMER: I don't know how "correct" my method of setting lash on a hydraulic system is, its just the way I was taught. Point of fact: my 305 seems to have a compression problem and a detonation problem at WOT.
Last edited by Quasi-Traction on Sun Jul 16, 2006 4:09 pm; edited 2 times in total
PostPosted: Sun Jul 16, 2006 4:07 pm    Post subject: Reply with quote
cool man. It might have been just an oil starvation issue. I've noticed it a lot on 3.1's when they're cold. My mom's Oldsmobile does it when you first start it up. When you drive it for a few minutes, it goes away.
PostPosted: Sun Jul 16, 2006 4:23 pm    Post subject: Reply with quote
Might have been a heat thing. What viscosity oil do you run?
PostPosted: Sun Jul 16, 2006 4:51 pm    Post subject: Reply with quote
10-30 i think.
ok, so if the problem does not kreep up again (like tonight when i drive it COLD) i will not worry about it. i will consider it a fluke brought on by running the engine HARD and disregard it.
however, if the problem persists on a cold engine what should i do? the engine never did it when cold before, therefore it is not "normal" on my 2.8, and i would like to get rid of it (the problem, not the 2.Cool.
PostPosted: Sun Jul 16, 2006 5:00 pm    Post subject: Reply with quote
Personally, I'd adjust the valves anyway, just cause it would drive me insane thinking that something was wrong.
Why'd you race that beater six anyway? Too many miles for that kind of thing.... Laughing
PostPosted: Sun Jul 16, 2006 5:05 pm    Post subject: Reply with quote
two reasons.
1. until now i had NO way of measuring the cars performance. and this is cheaper then a dyno.
2. i recently picked up a t-5 swap for my GTA and wanted to see how to launch a stickshift car on somthing W/O enough power to damage the tranny incase i did somthing realy stupid.
PostPosted: Sun Jul 16, 2006 5:08 pm    Post subject: Reply with quote
Hey, I got some prime real estate around town you can use to test it out without paying $25. Plus no one will b*tch if you sidestep it high enough to kick your rear end around. Very Happy
Danked
Banned
PostPosted: Sun Jul 16, 2006 9:45 pm    Post subject: Reply with quote
was it low on oil or water? when either was low on the pinto it was making similar sounds.
PostPosted: Sun Jul 16, 2006 10:04 pm    Post subject: Reply with quote
no, all fluids are topped whenever a low condition is observed.
PostPosted: Sun Jul 16, 2006 10:21 pm    Post subject: Reply with quote
C'mon man... you know if Tony is going to blow up his cars, it's going to be for a good reason. Razz
Besides, any problems you might have had with that Pinto are probably dirrectly related to the fact that it is a Pinto.... Shrug
PostPosted: Sun Jul 16, 2006 10:32 pm    Post subject: Reply with quote
ha! awsome. and a good point.
so i drove it again tonight COLD and the problem did not persist. however i believe i am going to re-set the valve lash anyway, just to be on the safe side. i have never actualy had the valve covers off of this car before, it will be a fun learning experiance. in addition to ensuring the wellness of my valvetrain, i am also hoping that with ther engine that torn apart i will be able to get a good enough angle on the manifold bolts to remove my exhaust manifolds. i have had a minor manifold gasket leak since i purchased the car in sept 2003, i tried to loosen the bolts once and was unable to do so due to the crampt nature of that side of the engine bay, however with all the other crap out of the way i believe i will be able to get that taken care of. all in all tomorow will be a productive day.
if anyone wants to help i will probably be getting started around 10am at my dads place in hillsboro. lunch is on me. PM for directions.
PostPosted: Mon Jul 17, 2006 11:42 am    Post subject: Reply with quote
That is your ticky sound. Not the valve lash. Period.
PostPosted: Mon Jul 17, 2006 12:03 pm    Post subject: Reply with quote
Bashy Bashy Absolutely. Had the same problem on my car. You gotta tell us these things. Laughing
90droptoproc
PostPosted: Mon Jul 17, 2006 5:46 pm    Post subject: Re: i broke my car at the track... sort of... Reply with quote
he did
PostPosted: Mon Jul 17, 2006 9:34 pm    Post subject: Reply with quote
loose exhaust bolts?
PostPosted: Mon Jul 17, 2006 9:57 pm    Post subject: Reply with quote
If they're that loose, the gasket itself is probably already burned beyond usefulness.
PostPosted: Mon Jul 17, 2006 10:18 pm    Post subject: Reply with quote
Some of these cars don't have exhaust manifold gaskets. Mine didn't until I put in the new motor. Parts guy at West Bay told me this was common on some Chevy motors.
PostPosted: Mon Jul 17, 2006 11:20 pm    Post subject: Reply with quote
it's tight, just not tight enough not to leak...
