Posted: Wed May 24, 2006 9:02 am Post subject: Rodney's Rod Ends |
Hey Rod... you've done stuff with rod ends....
How do I get
To look like
With the spacer deal in the center for LCA's? IF it's just a piece of steel, wont it slide back and forth on there? |
Posted: Wed May 24, 2006 11:18 am Post subject: |
What is the hole diameter on the rod end that you have Paul?
The LCA bolts are probably 12 or 13 mm in diamerter. If you had a 3/4" rod end then it would be pretty simple to make a press in bushing the same width as the stock LCA rubber bushing to eliminate any side to side motion. |
