Some welding trouble
Goto page Previous  1, 2
84transam383
Banned
PostPosted: Fri May 19, 2006 4:57 am    Post subject: Reply with quote
you have to run 4th gen panels for it to look right,otherwise you have HUGE gaps on each side of the car,snag up a 4th gen dash of your choice,and some panels,and ill help you do the swap Very Happy hell ill even wire up the cluster so it all works like it should
PostPosted: Fri May 19, 2006 8:39 am    Post subject: Reply with quote
WHY?
PostPosted: Fri May 19, 2006 10:21 am    Post subject: Reply with quote
chris. a compotent welder can fill a 3" gap. it will take a while, and it might not be as string as the original solid piece, but it would be done.
there are two ways:
1. use other metal (from the pieces we cut out of the 84) as a patch and do two lap or butt welds to get it in there.
2. fill it with weld. this is harder but more fun.
when i was in metal shop in HS i used to take two pieces of scrap, usualy of different thicknesses and place them in an overlapping "V" shape. i would bridge the gap with weld, welding on weld for as far as i could. i think my record was two inches. we had damn good welders, but i would like to think some of it was due to my skill. i reeeaaly miss welding. i have often thought of dropping major cash on a good Lincoln or somthing just to play with it. but i don't realy have that kind of "fun money" lying around. if i did though i would buy a wirefeed. i never licked torch welding, stick was ok, but wire feed was the most fun, mostly because you did'nt have to stop every 5 seconds to get a new rod. lame.
84transam383
Banned
PostPosted: Fri May 19, 2006 12:49 pm    Post subject: Reply with quote
BigDaddyVu wrote:
WHY?
why what? if your asking why you have to run 4th gen panels,its because the 4th gen dash is narrower by a few inches then the 3rd gen dash,the 4th gen doorpanels which "fit into" the 4th gen dash,fill up this gap,if youve ever been in a 4th gen you'd know what i was referring too.
PostPosted: Fri May 19, 2006 3:25 pm    Post subject: Reply with quote
there are two ways:
Let me Rephrase:
A competent welder will use a piece of metal properly fit within the gap and either V-groove the joint for 100% penetration, or lap joint the pieces if heavy structural integrity is not an issue.
A competent welder will NOT fill a 3" gap with only filler metal. The result would be a hodge podge of porosity, wasted time/materials, and a fugly weld.
Cool
Thus concludes our welding tutorial for today.
PostPosted: Fri May 19, 2006 4:16 pm    Post subject: Reply with quote
well yeah.... you would not DO it, but you would be capable of doing it. Very Happy i used to do it for fun.
this is not somthing that will be holding alot of weight, i would overlap the pieces and do lap welds just for ease of welding.
PostPosted: Fri May 19, 2006 5:55 pm    Post subject: Reply with quote
So..........who wants to do it?!?!
Cheers
Page 2 of 2
